Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Motherboard repair RE: intel D845EPI motherboard Are these boards repairable? Do you know a good source for repair? THis motherboard was compatible with XP. Can the Western Digital hard drive be removed and placed in a windows 2000 machine as a slave? That is of course if the EPI board cannot be repaired. Regards, Jim
    President:
  • 2,351 Answers
Hi Jim, I can not say if the board could be repaired. Repairs would depend on the problem. Best Buy would be my first choice if you decide to try & have the board repaired. Ask for an estimate before agreeing on repairs & ask for the cost for the estimate as well.
Finding replaceable parts may be an issue, again depending on what is broken. The cost for repairs may end up being higher than a new board & usually is. I see no issue with removing the hard disk drive & slaving it into another system.
You can still buy the board, click on this link
http://www.upgradebay.com/c1_itemdetail.asp?rid=gg&itemid=168739349&gclid=CMPjpcnlkpUCFQikHgod1AJrfQ
Manual Link: ftp://download.intel.com/support/motherboards/desktop/D845EPI/PI_English.pdf
Good luck Jim!
Mike
Posted on Aug 16, 2008
Hi, I need Intel mother board Audio video & all drives for a D845epi / D845gvsr. Thanks Arjun
All the drivers for you motherboard can be downloaded from the following link:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845EPI
Nov 16, 2010 | Intel D845EPI (INTELKD845EPILPAK10)...
Can i know my mother board(intel d845epi /d845gvsr)support ddr1 ,if supports will i have any problems in future.
Dont know if i understand your question right, but il give it a try¨
Here is what your mobo supports in memosticks:
The Desktop Board D845EPI has two DIMM sockets and supports the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR333/266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
  • Suspend to RAM
If you stay to those memosticks you wont have any problem at all, not now and not in the future.
And here is the support site for that mobo of yours:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1066
Good luck to you
Please take a moment and rate my help for you in a FAIR way
Nic
Feb 26, 2009 | Intel Desktop Board D845EPI Motherboard
Supporting ram for d845epi/d845gvsr
This link will provide you a list of ram modules compatible with that board. You should be able to reference the part number on your existing stick to check whether it's fully compatible.
Note: I am not affiliated with the linked vendor in any way, it is for illustrative purposes only.
D845EPI/GVSR video driver for vista
Your motherbaord uses legacy display driver, meaning Intel has stopped updating the video driver for it. What you can do is the following, it works as I have done it for many of my customers.
Open device manager>select display adapter and (right click) to choose update driver>select browse my computer for driver>click let me pick from a list of device drivers on my computer> on the next window uncheck "show compatible hardware"> you will see various display drivers made by various manufacturers (select Intel)> and from the next shown list select "Intel (R) 82865G Graphic controller" and install. Windows will give a warning on its incompatibility, but its ok go ahead and install.
The above mentioned work around should work. Try it and let us know. But Windows Aero effects will not work as the display card on your motherboard does not support it.
Feb 03, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Hello dear i have Intel Desktop Board D845EPI . wanna buy it ?
contact with me
Farhan Ayub
+923346841405
Jan 09, 2009 | Intel Desktop Board D845EPI Motherboard
IT USED TO RESTART ABRAPTLY BUT NOW NO DISPLAY
Hello Arua
I would suggest you get your hands on a 4 digit post card to diagnose the problem
heres one
http://cgi.ebay.com/PC-DIAGNOSTIC-CARD-4-Digit-PCI-ISA-POST-Code-Analyser-N_W0QQitemZ130196339829QQihZ003QQcategoryZ162QQcmdZViewItemQQ_trksidZp1742.m153.l1262
  • Determine defects by difference sounds coding with build-in speaker.
  • It can diagnosis the motherboard signal which show the problem of CPU, Memory, video card, etc.
  • The POST code display is made up of a dual, dot matrix hexadecimal read-out that display's Power On Self Test (POST) status codes
  • Support the power source working indicator -- +5V,+12V,+3.3V and 12V(When indicator LED is on to indicate its respective power is fine, otherwise to indicate its respective power is failure.)
  • Fully compatible with any kind motherboards which has the PCI and ISA bus slot.
  • If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
    on the ask me button, I will ansver in most cases within 24hours.
    Thanks and good luck!
    May 05, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    No display
    your board is having problem plz send it for repair
    Apr 22, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
    219 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
