Question about Maytag Dishwashers
Maytag Mdl MDBTT59AWW - Went into Diagnostics Mode- all indicaters blinking secquencially. Suspect random button pushing by a 7 yr old. Powered unit down and back up - Now nothing works.
  • dmageeenterp May 29, 2011
    The 7 minute power cycle got me out of the sequencing indicators. Now I can select any wash and dry cycle I want - when I press the Start the lights selected stay on for about 30 seconds and then go off, but the unit does not START. I also tried the Delay and Cancel button reset but got no results.
    Sorry, 7 minute control reset turned OFF sequentially blinking lights. Unit now looks normal - no lights..
    Now select Heavy Wash cycle - Heavy Wash Indicator comes on - Options Heated Dry and Extra Rinse Indicator come on. These OPtions can not be deselected - after approx 30 seconds all indicators turn off. Also the same happens when I select the Normal Wash and Light Wash Cycles.
    When I select the Rinse Only cycle only the Rinse Only Indicator comes On, the Heated Dry and Extra Rinse (Options) indicators do not come On. Hitting the START/ CANCEL button has no Effect.
    The Unit does not START and after 30 seconds all indicatiors go OFF
  • 1,998 Answers
First thing to do is go to your electrical breaker and try turning the unit off for 7 minutes and then turn the unit back on this usually resets the control. If this does not reset the control and you still have the same issue try pressing the delay /resume button once and then try pressing the drain /cancel button twice when you press each button count 1 second if this doesnt work message me back I await your reply Thanks Rick
Posted on May 28, 2011
  • Rick Ead
    Rick Ead May 29, 2011
    ok so the 7 minute control reset thing worked and now you when you press the start which lights are lighting up or blinking and if they are lighting or blinking how many times this is usually a sign of the unit giveing you an error code I await your reply Thanks Rick
  • Rick Ead
    Rick Ead May 30, 2011
    so now no matter what you push you do not hear any water going into the unit nor do you hear the unit starting to wash in no way shape or form if this is true if you have a multimeter you would check the solenoids on the top of the water inlet valve after you pushed for any cycle if you had no power to the soilenoids then there is either bad float switch which would make the unit not turn on at all or a bad control or touch pad on the unit i dont think its a touch pad due to you pushing buttons and them lighting up one of the first steps you should have happen when you push for any type of cycle is water flows in the unit from the water inlet valve message me back if this is not happening Thanks Rick
I have an old 3 button digital push button watch that I cannot set the time and date for. the top button is "ST/STP", The middle button id "LAP/RST", the bottom button is...
hold in the mode button until it flashes.5 sec.use the right buttons to move the hr up and down. make sure it is pm or am , usually pm is shown and no am. , press mode to set mins, press rights ones to set mins, press mode. it will go thru time and date and yr. ect. last setting and mode will bring you to a set dial. not blinking. some cases rest the whole thing first by pressing all buttons at once for 5 beeps. let go and sets to defaults 1200 and 0's.
Jun 17, 2011 | Watches
Display blinks sudden beeps
We provide free diagnostic information for our customers when you provide us with your model number and the brand of appliance that you are having a problem with.
We are available from 7 AM - 7 PM CST to answer all your appliance questions.
We also provide part removal/installation instructions when you purchase your parts through us.
We look forward to getting you cooking again soon.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service.
We hope this helps! Thanks, Ella
Feb 27, 2010 | Maytag Kitchen Ranges
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
204 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
