Question about Refrigerators
Have turned thermostat up but fridge not cold (10C). Freezer OK. Occasional lound banging noise from back of fridge freezer. Thermostat was changed about 2 years ago. Machine is 15 years old. Any ideas?
    Genius:
  • 2,920 Answers
The compressor is going out
Posted on Aug 16, 2008
Freezer working fridge not somtimes a bang noise
The banging noise is ice growing in the freezer and over stretching the interior.
Manually defrost the freezer.
Then run the refrigerator again. If things appear normal again then the automatic defrost is not working. A technician can sort that out for you.
If the fridge still is not cooling then the freezer fan is probably broken as well. A technician can help you there
May 02, 2011 | Refrigerators
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Fridge won't stay cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Refrigerators
My GE fridge won't stay cold. The freezer up top seems to be cold.
How to check parts
Sep 07, 2009 | Refrigerators
Fridge not cold as should be
OR.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Kenmore elite, two doors. pull our freezer below. ref.not cold even at #7 setting (coldest). Freezer is working
OR..
Aug 21, 2009 | Refrigerators
Fridge not cold enough - freezer not too bad
OR
Aug 19, 2009 | Roper Refrigerators
My refrigerator will not keep cold. cold air in freezer none in refrigerator.
OR ..
Aug 14, 2009 | Refrigerators
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 02, 2009 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
