Question about KitchenAid KESS908SPS Electric Kitchen Range
I started to do a self cleaning on my Kitchen Aid range and I opened the door to make sure nothing was inside the oven as the door was trying to lock and the lock came out with the door open and now I can't shut the oven door completely because the lock is sticking out. I called the 1 800 number for KitchenAid and they were no help. The person I spoke to told me to hit the Control lock and that locked up all the buttons on the oven so now I touch a button and it beeps at me. I turned off the breaker to the oven and a message came up Recent Code 0064 and AM71 UI75 EEKEO-068. I have tried everything I can think of to fix my oven. I need someone to help give me the solution to fix the problem. Thanks, Dustye Gonzalez
  • 2318 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
  • 17 Answers
SOURCE: I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: Self cleaning does not work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Posted on Oct 01, 2010
heatman101
  • 43501 Answers
SOURCE: Kitchen Aid Gas Range Architect Series II-self
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Nov 27, 2010
Has anybody had the problem of the oven door staying locked and won't open after cooking and has cooled down for several hours?
The oven door lock should only lock during self clean only. SHould never lock during normal oven functions. While in self clean because of high temps, the door lock will remain locked for safety reason until the temps drop to about 350 or so then release. Thats how the lock system works. If you select the normal bake mode and your door locks you may need to have the latch adjusted or the unit checked for problems. Good Luck
Apr 01, 2016 | KitchenAid Kitchen Aid - KERS505XSS...
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Kitchen aid gas range KGRS807, 901 or 907
The only time that the oven door should be locked is during the internal "Self Cleaning Cycle," due to the high temperatures used. Make sure that the display does not indicate that the oven is not in it's self-cleaning cycle, and try wiggling the door slightly to see if you can dislodge the sticking lock pin.
If this does not help, then I suggest that you Call the KitchenAid Customer eXperience Center toll free: 1-800-422-1230
Aug 30, 2015 | Kitchen Ranges
Kitchen Aid Gas Range Architect Series II-self cleaned the oven; it is done the oven is cold but the door is locked and nothing works on the control panel.
heatman101
Nov 25, 2010 | KitchenAid Kitchen Ranges
Nov 14, 2009 | KitchenAid KGRS807S Gas Kitchen Range
PUT THE OVEN ON SELF CLEAN AND IT DIED
the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
Oct 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
My oven door is open but the panel is flashing "LOCKED"...
Pull the plug, wait 5 minutes and plug it back in. Don't touch anything! First check to make sure the door closes. If it does you are ready to set the self cleaning mode.
Mar 26, 2009 | GE J2B915SS Dual Fuel (Electric and Gas)...
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Oven door locked
Please check my earlier post on this problem.
I forgot to add that the only way the Tech is able to get the oven door unlocked after it shuts down in the Self-Clean (Self-Destruct?) mode is to take a pair of pliers and short across the bad Thermal Protection swtich before replacing it.
Mar 22, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Open Questions:
KitchenAid KESS908SPS Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
