Question about Pool & Spa
Softub hydromate unit leaking from the bottom only when jets and power is turned off? hoses seem to be connected properly? How do I fix it and can I still use my softub with it leaking?
3 Suggested Answers
  • 69 Answers
SOURCE: softub pump appears to be stuck, when it starts it
call a service rep out from a spa center, water and electric are not a good combo.
Posted on Dec 07, 2009
john224
  • 1378 Answers
SOURCE: Softub about 4 years old - I have a leaking water
Thank you for posting your question here on Fixya.com.
Neither...it is threaded onto the motor shaft. Lock the shaft at the end opposite the impeller and turn it off counter clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 13, 2010
Testimonial: "Thanks John - very helpful"
Hi I have petrol leaking from my Yamaha virago 535 via bottom of air intake when petrol pump kicks in after turning key . can you help please
If petrol leaking from bottom of air intake if air intake is connected
to carberator most likely the float needle jet is not seating properly . Try replacing needle jet it is connect under the floats. Motorcycle will still run but fuel will leak out carberator. Try
Feb 18, 2015 | 1992 Yamaha XV 535 Virago DX
Why is insinkerator badger plus 5 leaking from the bottom?
Check hose and connection from the dishwasher to the unit. Look for cracks and proper installation.
Apr 22, 2012 | Electrical Supplies
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
It does not pick up debris and there does not seem to be any suction on bottom of unit
Try these troubleshooting techniques for this automatic pool cleaner. First, check the thrust jet and make sure that it is getting proper thrust. Check the filter screen in the in line filter and clean it is necessary. Make sure that your skimmer basket and pump basket are clear of obstructions. Check your hoses and connections to make sure that you don't have any leaks. A loss of water pressure could be your problem.
Jun 09, 2010 | Polaris 180 In Ground Pool Cleaner In...
Jet tub
Is unit getting proper power(check circuit breaker panel ,mayby unit was never turned on).Unit may not have beed installed properly.If unit usees button on top of unit check check and make sure air hose is connected at both ends, at button and at control unit.
Oct 06, 2009 | Home
1996 GMC Suburban Brake and Power Steering Failure
if you got the hydro brake boost system .check your power steering pump hoses for leaks .check master cylinder is leaking. fill power steering pump and master cylinder with fluid. the one that is the lowest that the one leaking. if your hydro boost brake unit is leaking .replace it .if power steering pump leaking. it not the hoses replace it . because if power steering goes out brakes will also go out.
Apr 29, 2009 | 1996 GMC Suburban
Danby DDW496W Leaking Brand new
Check your hose connections in the back for tightness and sealing (there should be some rubber seals inside the screw-in connections) and if tight and not leaking, you might have a loose clamp inside the unit, or a leaking/damaged hose, or even a defective/leaking pump. If it is brand new and returnable I'd return it for a new one rather than try to fix it...
Apr 05, 2008 | Danby DDW496W Free-Standing Dishwasher
Leaking solution tank / m/n f5881-900
Check th reservior unit, part #43516008, is the solution tank seal that sits on top of the reservior unit ok and in the right position? Is the control rod, inside the handle releasing when yuou release the trigger? Are the hoses attached to the reservior unit. May have to replace the reservior unit. Also check the valve at the bottom of the tank to make sure it isn't stuck open. Push it and see if it comes back down. Here is a picture that may help:
Jan 23, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Pool & Spa Logo
701 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
