Question about Texas Instruments TI-83 Plus Calculator
Put regular aaa batteries and it wont turn on
  • Scott Smith May 28, 2011
    Have you tried raising the contrast?
  • kakima May 28, 2011
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone over two months without a response to my query, I assume my suggested contrast adjustment solved the problem.
Posted on Aug 10, 2011
My remote wont take a standard aaa BATTERY what type do I buy?
maybe it is a AA battery that you are trying to put in or are installing the AAA wrong
AAA and all batteries come in standard sizes and there are no special sizes for your remote
Jul 04, 2017 | Televison & Video
1991 toyota camry wont start - lights on inside car - no clicking sounds - battery was jumped next day still wont start
No clicking sounds that means when your contacts touch to ignite your starter it is not working your starter is broken
Feb 08, 2018 | 1991 Toyota Camry
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
The base unit for my Philips VOIP3212S is not charging the phone I need to buy a replacement base unit. I put ordinary batteries in the phone and the base unit no longer works
Wilson - The phone was not made to use regular (AAA) batteries. Unless you install AAA NIMH rechargeables it will not work. Regular AAA batteries cannot be charged by the base unit.
In case you meant AAA NIMH batteries as "ordinary batteries" then your charger may be the problem, but I wouldn't assume that until I've taken a pencil eraser and vigorously cleaned the base contacts and tried the base again (with the right batteries.)
Good Luck, Mikeywaf
Mar 07, 2011 | Philips VOIP3212S/05 IP Wireless Phone
I have Model MDR-RF970R and the battery is not holding a charge. Where can I get another battery? The # on the battery is BP-HP550-11/2.4v 550mAh. Thanks. Joe
Sony has some special case they put around the original 2 batteries to hold them together.
You don't need to buy special batteries. You can put regular AAA NiMH in.
To remove the compartment cover on the headsets make sure you hold down the pressure button on the left headphone to release the cover. Mine has the words "PUSH" on them.
With the cover removed you can then see the original BP-HP550 sony battery. Which you can remove and put 2 regular AAA batteries in.
Oct 07, 2010 | Sony MDR-RF960RK Consumer Headset
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
Polaroid camera a800 i first bought it put batteries in and Sd card then it just blinks red and say goodbye
This happened with mine too. Mine is an a800 polaroid digital camera. i had some AAA batteries from an old remote control and they didnt have any juice left in them after 5 minutes. So i kept trying different AAA batteries and it wont even turn on!
Sep 01, 2010 | Cameras
I bought a motorola Talkabout, a set of three, and only got 2 batteries.
I put three AAA bateries in it! I still think you should include batteries when you sell a product with rechargeable batteries that you can't buy anywhere!!!! So I wont be able to recharge the regular AAA batteries. Yeah I am still burning over the problem.!!!
Jul 29, 2008 | Motorola Cell Phones
It wont turn on
Well, you can either try another AAA battery, or buy the same MP3 from a different store.(Be careful, some stores stock defects of items, such as MP3's.)
May 17, 2008 | iLO MP3 Player
Texas Instruments TI-83 Plus Calculator Logo
24 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
