1998 DODGE CARAVAN 2.4 4CYL . TO CHANGE THE EVAPORATOR CORE , DO I HAVEE TO REMOVE THE COMPLETE DASH .
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 216 Answers
Yes, the dash will have to be removed as there are three interior nut/bolt combinations that will have to be removed that cannot be accessed under the hood.
Make sure to check everywhere for leaks and not just jump to the evaporator core. It's a lot easier to replace a hose than it is to replace the evap core.
Posted on May 28, 2011
How do I remove a/c evaporator core from a 2000 dodge caravan
You will have to evacuate the freeon
Which must be done with regulated equipment ,
If using the new gas , you will have to use new seals , use flushing ,liquid ,renew the oil and re gas .
Sep 29, 2014 | 2000 Dodge Caravan
Heater core 1999 dodge caravan
To replace the core means the complete dash assembly must be removed. This job takes allot of skill and about 10-14 hours to complete for an amateur. You will absolutely need the factory manuals to have any hope of getting it all back together again and all systems work. You can download the factory repair manuals here.
Oct 26, 2012 | 1999 Dodge Grand Caravan
Remove rear evaporator core 2008 dodge grand caravan
it is inside the right rear corner of the van with line connections under the van you will need to remove the plastic cover inside the rear corner
Jun 28, 2012 | 2008 Dodge Grand Caravan
Trying to locate the heater inlet hose for a 1998 dodge caravan
I had a 98 caravan for 3 years, but I don't have it anymore. Going off memory but I recall both the inlet and outlet hoses are near the center of the firewall directly below the windshield. If it is a 3.3. or 3.8 the Intake Plenum is kind of in the way, but it is not difficult to remove.
If you are planning on removing the heater core, good luck. I have heard the whole dash must be removed.
Aug 12, 2010 | 1998 Dodge Caravan
How to install a heater core on a 2005 dodge grand caravan
Very easy if you go through the lower part near the peddles
Dec 24, 2009 | 2005 Dodge Caravan
I need to know how to remove the evaporator coil on a 2000 dodge grand caravan. i have already removed the dash and all the duct work but i dont see how to get the box out that contains the heater core and...
Woo hoo i finally did it. To remove the a/c-heater housing unit you have to remove the dash, the duct work, and all the metal framework behind the dash.Its a lot of parts and it takes time but its doable. Just be careful and make sure you pay attention or label everything. Once you get the housing unit out, its cake from there. Just take all the screws surrounding the blower motor and then it will reveal more screws. So continue to take screws out and the top will come off. Then there it is, remove the evaporator coil and remove the expansion valve and place on the new evap coil and installation is reverse of removal. Thanks for help and this is cool I solved my own problem.
Oct 24, 2009 | 2000 Dodge Grand Caravan
I have a heater core blowing steam on the wind sheild.On my 2001 Dodge Pickup 1500 4x4 with a 360.How do i go about changing it.
first you have to remove the complete dash . recover the refrigerent for the a/c. I would advise replacing the heater core AND the evaporator at the same time. Dodge trucks are very common for both and you dont want to do the core and then a few months later the same job over again.
Sep 18, 2009 | 1988 Dodge D-Series Pickups
Heater core
Parts of the ABS & Lower steering column need to be removed & should only be done by an experienced technician, as airbag etc comes into play as well. The labor shouldn't be too much, so I would get a couple of quotes and go from there.
Sep 16, 2009 | 1998 Dodge Grand Caravan
Evaporator
You will need to remove the entire dash assembly to replace the evaporator core, unless you have a really good understanding about such work I would leave it to a professional, if you still want to do the job yourself post any questions you have about removal of the dash and I will try to help as much as possible.
Oct 12, 2008 | 2002 Dodge Caravan
A/C Evaporator repacement
remove screws from housing, as well as blower motor. disconnect hoses from heater core and remove heater core. installation is reverse of removal.
Jun 30, 2008 | 1998 Dodge Ram 1500 4WD
Computers & Internet Logo
David Payne
David Payne
