How to install the micro sd driver in my hp laptop
  • 83 Answers
You don't have to install the micro sd its auto detectable... enjoy using it!
Posted on May 28, 2011
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
I cannot find the correct driver
which mobile do you have?
if nokia? then All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of datarecovery). how:
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3,4)
Step Two:
4. If you are using Win Vista or Seven, double click the file cp006049.exe - selectextrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next -selectdrive - Next - Create new or replace exiting configuration - Next - Hard drive -Next -Create new file system - Next - wait until the process is completed - Next -Finish.
Sep 26, 2011 | SanDisk 2GB microSD Memory Card
How do i load the drivers for my micro SD card reader on my HP compaq 7010
if you have done a rebuild using the discs that came with it the driver should already be installed
if not you may have to go to hp site, support, drivers select the driver you need and download it. it will be in a zip file and will open when you click it
Oct 30, 2010 | HP Compaq Business nx7010 Notebook
Acer aspire one won't see my olympus SD MASD-1 micro SD attachmen
You may need the card reader drivers installed. What is the exact model (110, 150, D150?) and operating system of your laptop?
Drivers can be found at the following link given the model of laptop, I can help you find it further if you provide the requested info above.
http://support.acer-euro.com/drivers/downloads.html
Mar 12, 2009 | Acer Aspire 4315 Notebook
Driver software for MicroSD needed?
http://www.spectec.com.tw/fix.htm
try the above link, it might be usefull
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
