Question about Aurora Electronics AS870CR Shredder
Aurora AS870CR. This has worked without a problem for several years but now just makes a strange thumping/springing sound every 1/2 second when plugged in. It doesn't shred at all any more. Took it apart and can't see any paper jams and gears look okay. Does it sound like the motor is burned out?
  • ngebc Jul 26, 2011
    Thanks for the solution. Unfortunately I threw the machine out last month and got a more heavy duty model so I can't re-examine the gears. Maybe your advice will help someone else with the same problem.
  • 42 Answers
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Check the plastic white gear very close it looks ok, till its closely examined the teeth wear out and they don't catch properly onto the metal gear. It gets smooth in spots. This causes it to sound funny and thump when it misses the gear.
Posted on Jul 25, 2011
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
Washer's external Drain hose dislodged at drain pipe, do you suspect the recent severe thumping spin cycle caused this to happen? Flooding occurred. How would you test drain hose? What could be the...
If you were flooded then drain hose does not seem to be clogged. Yes severe thumping would or could cause washer to bounce around enough to pull drain hose out. Thumping would be because of unbalanced load. Or worn dampers and/or springs. Post make and model for better answers.
Mar 23, 2015 | Washing Machines
My shredder makes a thumpping noise then stop. Inreverse it does the same thing. My model is Aurora AS701X-MS The motor runs but it does'nt shred the paper unless you shake the paper then it stops.
It sounds like one of the drive gears has broken. I have contacted this manufacturer before and was told that they do not make replacement parts for their machines. If it is less than a year old, they will replace the unit but that is about all they will do.
Jun 20, 2010 | Aurora Electronics (AS701X) Shredder
Radio cuts off and amplifier in the trunk is very hot! Is it the reciever or the amplifier? When it works, it sounds fantastic.....Mike
did you check if your cables are connected properly if amp is getting hot you might burn it up check your wiring make sure your ground is not loose if it is once you thump amp cuts off becauce wire is loose if that is the case
Sep 24, 2009 | 1995 Oldsmobile Aurora
Washer makes thumping sounds when spinning even without a load
Check under washer to see that you have not got a broken spring that is causing the drum to spin out of round.
Thanks for using FIXYA
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
My scooba seems to work fine but no longer makes the beeping noise. Several weeks ago the beep was sounding very strange almost like a battery was dying. Now it's not making any noise at all. Is this the...
Your speaker went out. It could be totally isolated. You're not going to be able to determine what's wrong with your Scooba if something does happen, though, because without those beep codes, there's no way for the robot to communicate with you.
If you're under warranty, call support at 1-877-855-8593 and let them know your speaker went out.
Jun 28, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
My subwoofer (Altec Lansing[AVS500]) is always makeing a thumping
You could only verify this by gaining access to the rear of the speaker but I suspect that the 'spider' has come unglued. This is a device that surrounds the lower (inner) end of the cone to provide a second point of suspension; without this, the voice coil can slap against the side or bottom of the magnet structure.
I don't think a repair is an economical choice for these; repairs only make sense for 'professional' speakers that cost several hundred dollars to replace.
Apr 13, 2009 | Altec Lansing 621 Computer Speakers
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
Thumping sound from all speakers
Ever find the cause of this? I have the same problem. Thanks Steve
Jan 21, 2007 | JVC TH-C5 System
Aurora Electronics AS870CR Shredder Logo
122 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
