Question about McCulloch 1400 Psi Electric Pressure Washerr#FH140A
Mc Culloch power washer FH140A The "on/off"
    President:
  • 3,074 Answers
Easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
Posted on May 28, 2011
  • benzaco
    benzaco Jun 08, 2011
    I just fixed mine. The springs don't go on the top of the metal pieces that rock up and down...they go in the two square holes. I had to try a couple different times before I got everything to seat properly.
  • Tim Whalen Jun 09, 2011
    Good Job and thanks for the information, Tim
Is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
Primmer button keeps sticking on my mc culloch 210 petrol strimmer
take it apart and clean it and remove what ever dirt that makes it bind easy to do ,
Mar 20, 2015 | Garden
Where can I buy a carburator kit for a Mcculloch chainsaw 3516 in toronto
I would start with a phone book looking under saw and ask if the shop services that brand. If not do they know who does. You could also try a web search for Mc Culloch.
Jan 20, 2014 | Garden
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
Mc culloch chain saw 742 manual need urgently
Both the OM and IPL can be found here:
http://www.mcculloch.biz/int/support/owners-manuals/
Just type "742" in the "Model Search" window and click Search. HTH
Lou
Feb 17, 2010 | McCulloch Garden
After having my Mc Culloch sharpened
You may have the chain on backward. The teeth on the bottom of the bar have to have the sharp edge coming at you in order to cut anything. Hope this helps you, Jeepfxr
Jan 28, 2010 | Garden
What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
Hello awseibel:
  1. attach your garden hose to the inlet (at the back I believe)
  2. Attach high pressure hose with gun wand/nozzle
  3. turn on the water
  4. plug into electrical outlet
  5. turn on/off switch on
  6. spray away
  7. Any non-caustic soap can be used
  8. You must set the machine on low pressure to apply soap.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
What is the oil-gas ratio and the bar oil for a Mc Culloch Mac130
You should be safe with a 32:1 mixture unless you are a logger. And any Bar Chain Oil should work fine.
Apr 15, 2009 | McCulloch Garden
I need a McCulloch FH140A pressure washer spray nozzle
you will have to replace the wand which you can purchase from a reputable hardware store
Apr 08, 2009 | McCulloch 1400 Psi Electric Pressure...
McCulloch 1400 Psi Electric Pressure Washerr#FH140A Logo
186 people viewed this question
Top McCulloch Plumbing Experts
Tom Chichester
Paul Carew
Are you a McCulloch Plumbing Expert? Answer questions, earn points and help others
