Question about Samsung RS2534 Side by Side Refrigerator
I have a Samsung RF263 french door fridge. The power went out during the recent storm and when it came back on, the temperature display lights are flashing 88. The fridge is still working and colling fine. Help
How do i replace the freezer door handle on samsung rf263
Usually you have to remove all the screws around the inside door panel...which are behind the door gasket, and throug the inside door panel...
May 25, 2014 | Samsung RF265AA Bottom Freezer French Door...
Reading on door OF
Teresa, The fridge is in a retailers demo mode and here is what you do to reset it to normal operation:
Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
  • At the top of the door frame: Simultaneously press and hold the "Power Freeze" and "Freezer" buttons until you hear a distinctively different chime sound and the temperatures for the fridge and freezer are both displayed.
  • Note: If the temperature is displayed, but then "OF OF" reappears a few seconds later, Cooling Off mode was not disabled. Repeat the actions above, and be sure to press and hold the buttons at the exact same time until the distinctive chime sound is heard and both temperatures are displayed.
Apr 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
The "water" light on the display panel went dim for a couple days and is now out. everything else seems to work ok. What's the problem? K
i have the same problem except mine is on a samsung RF26X side by side french door fridge and the cubed ice light went out. same as yours, the light was dim for 2 days and then went completely out. i've had the fridge since july 2010. did you get help with a solution?
Sep 20, 2010 | Samsung RM255LASH Side by Side...
My power went out and since it was restored my fridge won't come.
IIRC your refrigerator has an electronic control in the front face of the freezer door. Both sides have 3 buttons in a vertical column. Is there any sign of life on this control panel (IE do you see the stack of horizontal green bars lit up and does pushing the "freeze" or "fridge" button change them)? If not, then the most likely scenario is that you had a big power surge when the AC voltage came back and it blew out your control panel. If you can install an adequatley rated surge protector in the power line for your refrigerator you can prevent this from happening again.
Jul 08, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Jun 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
Door display freaking out
Very common, this unit was mfg by samsung for ge and maytag. Its your hi voltage control board located on the back. You might call maytag and see if they will pick up the costs for this repair. There was recently a major rework kit for the samsung and ge units, but maytag opted not to follow the same. Call them and raise heck and let them know your food costs that spoiled and that your afraid to touch it because of the actions of this ele problem.. G luck
Apr 02, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
304 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
