Question about Kenmore Dryers
The drum will turn, air flows through, but no heat. yes, the gas is on. help!
    President:
  • 3,074 Answers
Http://www.applianceaid.com/gas_dryer.html#noheat
Posted on May 28, 2011
Heats with front panel off, but not with front panel on
3b524099-f5e5-4a68-9cbb-7c75f853808e.pngAir Flow issue sounds like. Is there go air flow at the rear of unit? Maytags of this style usually wear out blower wheels which moves the air through the unit, check the blower wheel see if you can move it without turning the drum, This is of course with the front panel off, The blower wheel is item #4 in the diagram and it's locate just behind the front panel.
Oct 26, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
I have Miele t9800 gas dryer . After 5 or ten minutes the check vent filter light blinks and beeps. Then unit turns off. No heat. The drum turns and air flows. Vent and filter have been thoroughly...
it is not sensing enough air flow. Remove the hose at the rear and check the whole pipe for fluff. Also check that the outside vent is not blocked and any opening flaps are okay.
Feb 25, 2018 | Miele T9800 Electric Dryer
The drum will turn, but no heat
Well if it's a gas dryer and if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Kenmore Dryers
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 23, 2009 | Kenmore Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore gas dryer heats some of time MD
Is the drum turning and are you getting a flow of air out of the exhaust pipe? These two items may assist you in finding the problem. Look next at the thermostat if these items are working right. Have you checked the area below the lint filter for buildup of lint?
Feb 25, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryer stopped drying.
IS IT HEATING? IF YES, IS THE DRUM TURNING? IF YES,
THERE IS A RESTRICTION IN THE AIR FLOW SOMEWHERE.
CHECK THE OPERATION WITHOUT THE VENT ATTACHED TO THE DRYER FOR ONE LOAD.DOES IT DRY O.K?
THERE IS A RESTRICTION IN YOUR EXHAUST.MAKE SURE YOU DON'T PUSH THE DRYER TIGHT AGAINST THE WALL. YOU MIGHT PINCH OFF THE FLEX VENT MATERIAL. YOU CAN'T JUDGE THE AIR FLOW BY VIEWING WHERE THE VENTING GOES OUTSIDE. IT MIGHT HAVE AIR FLOWING OUT IT, BUT CAN STILL BE RESTRICTED. REMOVE THE SECTIONS OF DUCT AND CLEAN OUT THE LINT FROM THEM. IF YOU HAVE FLEXIBLE MATERIAL RUNNING A LONG DISTANCE, GET RID OF IT. USE ONLY 4INCH RIGID METAL PIPE FOR LONG DISTANCES. THEN CONNECT TO IT WITH A SHORT PIECE OF METAL FLEXIBLE MATERIAL.
Apr 08, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
