Question about Poulan Garden
Poulan pro 600 6 hp push mower. When you pull start it, half way back thepull start jerks out of your hand and flies back in, meanwhile as this happens the motor turns over once, doesn't start, and a small amount of smoke comes out. Spark plug is good, has good gas and oil. Everything has been cleaned out. Any ideas? It has a briggs and stratton motor.
  • 252 Answers
Hi there kat forsaken
check that your blade and blade carrier is on tight
check your pto is not bent
then check the feather key in the flywheel its likley thats it has been bent / sheard and timming is out , hence the kickback - check 1st two items then replace the feather key think pt # is 222698
cheers pauly46
Posted on May 28, 2011
How do I change fly wheel key
You need to pull the blower housing off. Then remove the the starter cup from on top of the flywheel. Pry off the flywheel usually by insert a prybar under the flywheel pulling up while tap on the side of the flywheel. you will see the key in the center of the flywheel. after removing the old key, replace flywheel then insert key into grooves after you line the two grooves up.
Jul 11, 2014 | Poulan Garden
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
Primer pump lacation
Not all mowers use this feature to start their fuel flowing. Try using choke for 2-3 pulls, and reduce to half-choke if it starts. If all else fails, make sure it's not flooded by opening up the throttle for a few pulls.
May 06, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan pro 18" saw locked up.. help
some thing desperately wrong here, if this is happening with recoil starter off the machine then the next step will be to whip the head off,but before you do that take take the cover and chain and bar off ,the centrifical clutch may be breaking up, let me know i am interested to know what is going on
Aug 15, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
I have a poulan pro self propelled lawn mower that won't start. It ran fine this morning, but after I took a break and went back outside to finish mowing, it wouldn't start. It sounds like it won't...
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
This hapened on my mower and it turned u that the spark pug was too bigfor the motor and the valves were totally broke!!!Not good...
Jun 06, 2009 | Poulan Pro " Pro" Self Propelled Mower
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
166 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
