Question about Refrigerators
Where is the defrost timer on model AFF2534FEW refrigerator? What's this advice going to cost me?
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 1073 Answers
SOURCE: Problem auto defrost refrigerator
loaded question any COULD be bad a volt ohm meter will tell you whitch one is bad
if this is a ge sxs i would check the defrost heater first
Posted on Jun 24, 2008
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
WHERE IS DEFROST TIMER ON MAYTAG 20.6 CU FT FREEZER ON TOP MODEL M1TXEGMYW
Your model does not have a defrost timer, it has something called an Adaptive Defrost Control Board. Your model uses this board=> HERE The ADC can be found behind the control panel inside the fresh food compartment above the top shelf item location 4 in this photo=> HERE
APPLIANCE911
Aug 27, 2016 | Maytag Refrigerators
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Can't find the defrost timer on my Kenmore refrigerator 596 series
If you get the complete model number which is located inside the refrigerator on a tag either on the upper left or right wall or the roof inside and then go to partselect.com you will get an illustrated blow out and you'll be able to see exactly where every part is
Sep 05, 2012 | Kenmore Refrigerators
Defrost timer
Not every refrigerator has a defrost timer. Those that do will most times have it behind the controls inside fresh food campartment or just behind kickplate at front and base of refrigerator. What is your model number?
Here are some examples=> GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Feb 21, 2012 | Refrigerators
My kenmore trio freezer is cold, but not the refidgerator is not, and there is frost and ice where the cold air blows in from the freezer.
Since Kenmore is manufactured by several different manufactures, you should find the model number off the equipment id tag and provide that so I can give you the best advice. It will probably be located beside the vegtable tray in that unit, but not always.
You have a defrost system failure. Your defrost system is made up of the defrost heater, defrost thermostat and defrost timer/control board (newer units have incoorporated the timer onto the control board). You will need an ohm meter to check the heater (if it isn't open - it is good) and the thermostat (low ohm reading normal 28-38 ohms) but the timer is a different story. So you will need to rule out the heater and thermostat before replacing the timer/control board.
Sep 30, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Where is the defrost timer located on the fridge? and how big is it?
It depend on the model and types of your refrigerator.
It is usually located below the chiller container which is below the freezer.
Where the temp control is, there's the defrost timer, some has separately.
Certain types and model vary the size of the defrost timer. some has 2'x4' in size.
It is usually a push button type.
Thanks for asking.
Jun 28, 2011 | Refrigerators
Where would i locate defrost timer on my ge bottom freezer refrigerator
Older fridges use a defrost timer to control when the fridge goes into defrost. Yours is a newer model and uses a control module which controls all of the fridge's functions including defrost timing. It does not have a defrost timer. It cost around $150. But I would check the defrost element first. A lot of problems with the defrost are usually a burnt out heating element. Use a meter and check that the element is not electrically open.
Dec 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model # 61282100 purchased in 2002-on two occasions this year the freezer was dripping water down to fridge -advice was to unplug-wait for ice build-up to melt-why is ice build-up happening and how to...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Kenmore Refrigerators
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
Jun 12, 2009 | Viking 42 in Built In Professional...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
