Question about Refrigerators
Fridge stopped cooling. light comes on but not cold. only 14 months old. we live where power supply can be iffy so power surges apply. is there a re set button anywhere on the frindge or compressor
    Genius:
  • 1,622 Answers
Hi,Your start relay is bad for sure however the compressor could have caused the relay to go bad. The only problem is that there is no good way to tell if the compressor was the cause for the bad relay. The best way to tell is to replace the relay. I understand what you are saying, it would be bad to spend money on the relay then it turns out to be the compressor but there is just no definitive way to tell.
If you have a meter about the only thing you can do is to make sure the compressor winding are not grounded out. Check to see if there is any continuity from any of the three terminals on the compressor to ground and if so the compressor is bad. Even if the windings are not grounded out the compressor can still cause the relay problem. Be sure to unplug the refrigerator and the wires off the compressor before attempting to make this test.
I will say that 95% of the time (or more) it is just the relay.
The reason the fan wasn't running is because the compressor was off on the overload which cuts the fan off as well. The fan should have been coming on every so often when the compressor cooled enough for the overload to kick the compressor back on. If that wasn't happening the overload may be bad as well.
Overloads give very little trouble but when they are cutting on and off like they do when the relay is bad sometimes they will go bad as well.
Also, figure out if it's a short term or long term problem. If it's a short term problem, you've got it fixed. If it's a long term problem, then you'll need to take care of the food in your refrigerator while waiting for a repair person.
Can you Quickly fix a Refrigerator that's not Cooling?
start with the settings of the fridge. Often, the cause of a refrigerator not cooling is simply a misplaced switch - have the settings to cold, and see if the refrigerator quickly comes on. If it doesn't, be patient as on some models the cooling part of the fridge doesn't come on right away.
Is there Power to the Refrigerator not Cooling?
The quickest way of telling this is if the fridge light comes on. If it does, then there is power going to the refrigerator. If it does not, there's a chance that the light is just burnt out, however it's good to check in other places. Check the circuit breaker - sometimes a power surge can flip a breaker without you knowing, and be the cause of a refrigerator not cooling.
If the circuit breaker doesn't fix the problem, roll the fridge out and plug in something else to see if you can get power to same socket as the refrigerator.
First place to check - Fan in the refrigerator's freezer
The fan is often a part of the refrigerator that can break down - there are a number of moving parts, and this helps circulate the chilled air. Take a moment and see if the fan is running
Check the back of the refrigerator when it's not cooling
Is the back of the refrigerator warm? Most of the cooling function circulates through the rear of the refrigerator, and when it happens, the rear of the fridge warms up.
Refrigerator not Cooling? Call a Qualified Appliance Repair Technician
When your fridge isn't cooling, you should immediately call a qualified appliance repair technician. Look for recommendations from friends or family, and have one dispatched as quickly as possible. Keep in mind that most companies will take a few hours to dispatch a technician.
When waiting for help, keep in mind that the most important thing is to keep your food in good shape. Ask a neighbor to use their space, and consider eating or cooking anything that is perishable. Food can be very expensive, and once it thaws, in many cases cannot freeze again. Cooking food then refreezing it can add valuable time to your situation.
Posted on May 28, 2011
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Freezer works fine but the frig is not getting cold any longer. item is 14 months old.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Maytag 24.8 Cu. Ft. Side-by-Side...
The fridge stopped working. what to do. its three years old
It could be due to following reasons 1 There is no power supply. Check the power cord and the plugs. Ensure that there is bend/breakage in the power cord. Ensure that the plugs are connected properly with the cord. If the lamp inside the fridge is lighting that means the power supply is OK. 2 The compressor has stopped functioning or burnt due to overload. 3 The gas has leaked out. You must have noticed less cooling over the months. 4 Check the thermostat switch.
For 2 & 3 you will have to call a technician. I hope you have been carrying out the servicing once a year.
Nov 03, 2010 | Whirlpool Refrigerators
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Fridge is not cold and freezer is not cold
f the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jan 10, 2009 | Maytag MSD2454G Side by Side Refrigerator
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Dec 19, 2017 | Jenn-Air JCD2290HES Side by Side...
I moved our 18 month old samsung fridge freezer Model SR281NW and one week later it has stopped working. The freezer fully defrosted and the fridge, even though it has the light on, is not cold
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
May 18, 2008 | Samsung Refrigerators
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
227 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
