Question about GE Refrigerators
Ge fridge Model# Gss25ifrf bb that makes/dispenses ice, but nit the water. When I push the lever I hear a sound but nothing comes out.
  • 8 Answers
The Water Tube Heater WR49X10173 will fix it. It fixed mine. You can call GE and tell them your problem, and if you're kind and persistent, they will send you a free heater kit. Worked for me. Otherwise check eBay.
Unlikely it's the control board.
Rumor has it this problem is caused by water vapor getting absorbed by the foam insulation inside of the freezer door, and then the insulation doesn't insulate as well, and the cold from the freezer reaches the water line.
However...about a year later, your problem will be back.
As time passes, it will absorb more moisture, and the heater kit will not work anymore. I've seen several posts where the problem came back, with no solution.
So here's your permanent fix-ya:
Buy a second heater kit, and remove the foil sticky wrapper from the wire. The center portion between the black heat-shrink portions is the actual heater; the other end wires are normal wire.
Wrap the center portion tightly around right where the water tube comes out of the door, just below the ice dispenser flapper. Put some large heat shrink (not electrical tape - it won't hold) over the two existing heat shrink portions to hold the loop tight against the dispenser tube. I then put some aluminum foil tape, used for sealing duct work, over the loop and onto a portion of the dispenser tube, to hold it in place.
Connect it the same way electrically, so you now have two heaters in the circuit.
Then reassemble. You will need to take a Dremel tool to widen the hang-down actuator that your glass pushes on to dispense, around the dispenser tube. I needed about a 3/4" wide slot. This is because it will hit the coil of heater wire. Also be sure wires are out of the way behind this actuator as you reassemble everything, or the switch won't work reliably.
Mine had been frozen solid for a year, and it started working in the 2-3 minutes after I connected the front panel, which powers the heaters. Amazing!
The theory I used to come up with this solution is this: put gently heated air up the dispenser pipe, and it will steam the ice away. Voila!
Enjoy your water dispenser.
And yes, it's a very bad design, putting a water tube through a freezer door. What were they thinking?
Posted on Jun 15, 2015
My experience with the GE model GSS25IFRF BB is that it's an over-priced piece of garbage. I bought mine from Home Depot in 2006 and I've had to have a repairman out to my house for this thing 3 times in those 6 years.
The water dispenser issue is a known flaw with this fridge which GE knows about but, sells it like this anyway. The water dispenser line freezes. There is no fix for it. You have to thaw out your refrigerator periodically and then your water dispenser will work again for a while.....but it'll freeze up again. The first time I called in this problem, GE sent a repairman out to my house and said that they'd need to install some $450.00 heating adapter into my fridge (which wasn't even 2 years old yet) in order to solve the problem. Real stupid suggestion so, I declined. Additionally, why would I pay another $450.00 to compensate for a known flaw in the design of this fridge? If this was GE's "official solution", then it should have been free.
Either way, if you spend any money on fixing this, you're wasting your time and money. This problem is built into this refrigerator and will remain as long as you own this fridge. Best bet is to just unplug it and let it thaw out - water will dispense fine for a week or so.
Good luck - you'll be calling repairmen out for this piece of junk quite often so get used to it.
The real solution to this problem is to get a better fridge. That's what I'll be doing soon with mine.
Posted on Oct 04, 2012
SolutionGuy
  • 331 Answers
SOURCE: GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Posted on Sep 25, 2007
roadbird383
  • 40 Answers
SOURCE: Fridge Makes Cubes But No Water
Sounds like a bad water solinoid valve.
Posted on Dec 09, 2007
RescueTech
  • 145 Answers
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Posted on Dec 13, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
SOURCE: ice maker not working bosch refridgerator
Had the same problem. If there is ice in the bin make sure the ice bin is in all the way. there is a
drive gear in the back that has to be engaged. If the
bin is emty open the little door where you can see
if there is ice, on the left you will see the square
end of the ice maker unit. Slip your fingers under
the front face, palm of your hand facing up so you
can feel the bottom of the front of the unit. Over
to the left you will feel a button that you can not
see. Just push it in for a few seconds and the unit
should start. One other thing, make sure the limit
switch is pulled down, thats the plastic on the
wire which shuts the unit off if it is full. Good Luck.
Posted on Nov 01, 2009
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
WATER WON'T COME OUT OF THE DISPENSER IN THE DOOR
Check the solenoid valve in the back of the fridge near the water supply connection. If you don't hear any clicking from back there when you press the lever, then the valve is probably bad. Open the back and look for two valves in an assembly - one for ice and one for water. Sometimes the solenoid coil burns open in one or the other, and you have to replace the whole assembly. You can disconnect the solenoids and check for continuity with an ohmeter. It's not a complicated repair. Good luck!
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not dispensing ice out front
could be frozen auger motor, try turning motor by hand.
May 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
NO WATER OR ICE AT DOOR OR IN ICE MAKER
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
May 03, 2008 | Refrigerators
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Sep 24, 2007 | Refrigerators
Refrigerators Logo
256 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
