Question about Dryers
I have a Maytag Dryer Performa Model PYE3300AYW that want run, light does not come on either. Checked Breaker and it was fine, even replaced breaker to make sure, still no luck. Checked thermal fuse and there was continuity across it so it appears to be good, checked switch on front door and it seems to be ok, running out of things to check for next, HELP...
  • Anonymous Mar 20, 2014
    I have already checked the thermal fuse and the start switch and both have continuity. Door switch appears to be ok. Machine has 239.8V at the back.
    Problem Solver:
  • 6 Answers
Look on the wiring diagram for the dryer. Follow black wire ( + side ) from plug to motor checking all devices in the circuit, also check for any on the white ( - side). Do all tests with the Electricity OFF. Safety first!!! Good luck. BpB
Posted on Aug 16, 2008
  • bear1990 Aug 16, 2008
    Also if dryer is 220 volt elecrtic, first check to see if the power cord is attached properly to the terminal block connection and that none of the wires are burnt at the connection. They shoul all be tight. You can plug in the dryer when finished checking the power cord and its connections, which you check with the power off / cord unplugged. Safety first!!! BpB
I have a maytag performa electric dryer with no heat, checked fuses, replaced heat element and thermostat, any ideas
Have you checked to make certain you have the proper voltage where the dryer is plugged in? 220v? A dryer will run on 110v but requires 220v to heat. Could be a problem with the breaker in the breaker box. If you are not familiar with electricity, I suggest you find someone knowledgeable ie professonial
Mar 26, 2011 | Maytag Dryers
My Maytag Performa electric dryer will not start. The Model # is PYE2300AYW, Serial # 10923714ZB. It was working fine but will not turn on now. I have checked the breaker box and it is in the on...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 16, 2011 | Maytag Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag Performa (PYE2300AYL) dryer quit running in middle of load. It has been working fine for 7 yrs. I checked all obvious reasons (power supply, breaker, etc.) and then replaced the high limit...
the first thing to try wold be the thermal fuse.  you can check with an ohm meter and you will probably find it open up.  replacing is an easy one by please UNPLUG the machine first.
Aug 05, 2010 | Maytag Dryers
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Maytag performa dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Jun 05, 2008 | Maytag Performa PAV2200
Dryers Logo
249 people viewed this question
Top Dryers Experts
