I smelled something burnig and then curcuit breaker cut off tv. The tv willnot come back on
    Genius:
  • 1,622 Answers
Hi,There are a number of reasons that might prevent a conventional (CRT) TV from turning on. If there is power to the set and it won't come on, there is an electronic problem. There are start up circuits inside the set, and they essentially form a "loop" of sorts. Any "break" in the loop, that is, any failed component in the loop, will prevent the set from starting up.
Some sets have an internal fuse, but very few actually do. Protection is provided by components other than a fuse, and the failure of any one of them will "kill" the set. It should be noted that some components in the set fail because others have failed. The failure of multiple components is possible because of the design of the set.
It could just be the relay that turns the set on when the remote or main power button is press.
Some sets have a circuit breaker on the back that my have tripped. May look like a little red button that you press to reset. Some set have a internal fuse. This fuse is something that needs to be replaced by a professional. If it has a breaker on the back and you set it and it works, no problem. If you reset it and it trips again, have a pro look at your set.
check those and get back to me..
Take care.
Posted on May 28, 2011
Burnig smell from flat screen. Pic and sound ok.
the red flags should be up from the smell of the tv
something is getting very hot so take it in to a tv repair shop and have the problem properly diagnosed with a quote
if you delay then the smell could result in a fire and some tv's have been known to go up
Jul 19, 2016 | Televison & Video
Nec nw652 loud bang burning smell willnot run properly cuts on and off u think mayb the lid switch is the problenm
nope..you are toasting your control board in back, and the loud bang is most likely a really unhappy motor mount or tub mount
Mar 19, 2008 | Washing Machines
My dishwasher burnig smell and smoke coming out
Shut it off and go turn off the breaker on that circuit. If it's still burning, hit it with a fire extinguisher or call the fire department. Open a window to clear out the smoke and then call a repairman.
Jun 30, 2016 | Dishwashers
Curcuit Breaker appears to be on but no power?
It sounds like something in that circuit is causing the overload. Disconnect anything that is in that circuit, flip the breaker, and one item at a time plug whatever was on that circuit back in until it trips again. Then try that item in a different circuit and see if it does the same thing. It could also be that the breaker is worn out and is tripping at a lower point that it supposed to. In that case you would have to replace the breaker.
Mar 04, 2015 | Electrical Supplies
Wiring
Sounds like you have linked these up to ignition switch out feed to the kill switch/running curcuit rather than the lighting curcuit out from the ignition. most bike run 2 somtimes 3 curcuits out from the ignition switch one running curcuit and one lighting.
Feb 21, 2012 | 2007 kawasaki Vulcan 1600 Nomad
Smelling Pads
Hi; Did You clean the water curcuit with a good algaecide. If not That may be algae. And yes some hoghair filter media will slick up when first installed..alpharome416
Jan 17, 2010 | Mastercool 67680 Evaporative Cooler Air...
Still runs ok, but doesnt dehumidify anymore, and today it started smelling really funky....like something was about to burn up...
One of the connections to the compressor is shorting underneath the protective cap. It is a very strange design for this contact point. Hope you have a good circuit breaker on the curcuit that your unit is plugged into.
Sep 28, 2009 | Fedders A7DH45B2A Dehumidifier
Unit will not come on,power to everthing,but blower will not come
You probably have a bad breaker.
Check to see if you have 220 volts coming into the breaker. (while the breaker is in the ON position) and check to see if there is 220V coming out of the breaker. If no, then you have a bad breaker.
If you do, let us know and we can help you diagnose from there.
Jan 16, 2009 | Heating & Cooling
Air conditioner pop and then blew refriderant or something
Inspect the capacitor for failure. if it is not swollen or leaky then the compressor might be gone.264f733.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2009 | Kenmore Room Air Conditioner
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
