Question about Air Tools & Compressors
Where do you put the freon in a 98 windstar - Air Tools & Compressors
    Sergeant:
  • 188 Answers
Put freon on LOW side. - This line may also have a BLUE cap on the A/C fitting. This line is also the largest in diameter compared the the HIGH side., which is smaller in diameter. 1 - 2 cans max with A/C on, engine running..
Stay Cool....
Posted on May 28, 2011
98 windstar keeps dying
Ford Windstar Starting/Stalling Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Then yesterday the car just died while driving and had to be towed back to ... On pre-98 Windstar, it might be called CCRM (Constant Control ... Ford Windstar Alternator and Battery Problems
Oct 24, 2006
Ford Windstar Electrical Problems
Apr 14, 2006
More results from forums.edmunds.com
my battery on my 98 ford windstar keeps dying? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Mar 20, 2007 - while driving the battery will short out and sometimes turn right back on, causing the van to die. 2000 Ford Windstar battery keeps dying after changing alternator ...
Jun 23, 2010
Alternator keeps dying in 1995 ford windstar, already been through ...
Oct 7, 2007
Battery keeps draining in 99 Ford Windstar Van?
Sep 5, 2007
My 1998 Ford Windstar's battery keeps dying, why? Also the ...
Dec 16, 2006
More results from answers.yahoo.com
98 windstar 3.8 problems - CarGurus
Jan 23, 2016 | 1998 Ford Windstar
The blower on my 98 windstar blows hot air when in a/c mode and never gets cold. Tried charging it but It was already full.
the most common cause would be a slow leak in the system, and Freon might have been lost, causing warm air to blow Simply recharging an A/C system never fixes anything,so it needs to be checked for leaks
Jul 14, 2010 | 1998 Ford Windstar
Putting freon in the air condition in the ford
Yes you can go to pepboys or autozone they sell the freon in cans with the hose and gauge built in and follow the instrutions on the can
Sep 02, 2009 | 2000 Ford Windstar
Can a 3.8 motor from a 98 windstar be made to work in a 95?
would be best if you did lest hassel with electrical
Jul 16, 2009 | 1998 Ford Windstar
How would i charge my A/C in my Ford Windstar Van '98
buy a charge hose and pag46 oil charge/and freon about 3 cans 134a/u may not need all the cans but just in case its empty .//look for large ac line/hose and follow it to the small service port this is where u charge, the small line/hose with the large port is no t ur concern u can only hook up to low side ,,,,with ac on and engine running high blower max air,recerculation button on charge system untill ac stops cycleing on and off then charge about a 1/2can/dryer(large can looking thing should get very cold/more freon does not mean more cold so dont over do it
Jun 30, 2009 | 1998 Ford Windstar
Rear airconditioner blowing hot air on 1998 ford windstar,front works fine
check to see if there is enough freon in the system,if so eplace the rear expansion valve
98 windstar no heat
first of all check to make sure you put back the correct amount of fluid and then do this start the car up and put antifreeze in it and let it run till it gets to temp you may have an air bubble in the system then put the cap back on right away check the condition of the drive belt
Jan 18, 2009 | 2001 Ford Windstar
1998 Ford Windstar AC compressor
They get more than warm, but not excessively hot that you can't touch it. This can be caused by a faulty condenser fan motor, dirty condenser coil even low freon, which is my guess along with a dirty condenser. Check these two issues and if it's not the problem your compressor may be getting ready to die. because of internal issues with the motor windings. Make sure the fan is running to speed, clean the condenser and see if the larger copper pipe to the compressor is ice cold and sweaty, if not you may need freon
Jun 21, 2008 | 1998 Ford Windstar
Can a 96 Ford Windstar Air Conditioner Compressor Pump Fit in a 98 Windstar?
The compressor is the same but it may have a different pulley and the plug may be indexed on the wrong side. If you have a set of snap ring pliers you can put your coil and pulley on that compressor or it may already be the same ones just make sure you put the plug where it is on your original compressor.
May 18, 2008 | 2000 Ford Windstar
Air Tools & Compressors Logo
19 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
