Question about Epson Stylus Photo 1290 InkJet Printer
I tried many times to unblock the jets using the cleaning utility, no good, I cleared the jets by inject warm water using a seringe directly into each pin in the head carrier, the printer response as it should but I get absolutly nothing on the paper! Any idea's?
  • Ray Maskill May 30, 2011
    Thanks for the input gmeier,
    yes I carried out the head cleaning procedure and the ink flows fine but when I come to print test or anything I get absolutly nothing on the paper but the printer looks as though it is doing the print, the only thing not happening is the head is not placing any ink down.
    May be the electronics and sensors around the head are at fault, it looks like it is time for the bin!
    Guru:
  • 352 Answers
Hello.
After cleaning the heads with the warm water did you run the cleaning procedure through the printer again?? Cleaning the head with warm water is great, but you need to run the cleaning process after to prime the ink from the cartridge to the head. Also be sure to remove any Air-Hole stickers that may be on the cartridges.
I hope this helps Regards GM
Posted on May 28, 2011
  • Grant Meier May 31, 2011
    I would Agree, it sounds as if the head is not firing at all, and unfortunately to fix this can often cost more than a replacement.
    Good Luck
    Regards
    GM
How to unblock fuel injection of daewoo lanos1.6 16v
Fuel Injection Cleaning eBay
There are injector cleaning systems, and fuel injection cleaning solutions. Try the solution first in the gas tank. It may take a few doses and some time running the solution through the injection system.
May 17, 2014 | Cars & Trucks
Cloudy water
Always clean you jet tub as directed by the manual. If you don't have one, than fill tub above the jets, add liquid dishwasher gel (not tabs) with bleach and run through the jets for 20 minutes. Drain, fill with clean water and run two times to clean the tub and jets and then use. Be sure your metal filter is clean of hair and soap debris. This will keep your tub and jets nice and clean. Also recommend using Epsom salts and either essential oil of lavender or eucalyptus to your bath. Both essential oils have antibacterial properties. If you want it simpler, purchase Dr. Teal's lavender soak from the drug store. Happy soaking!
Oct 19, 2013 | Home
How to unblock rear window wiper water pipe on I10
Firstly have someone operate the rear washer while you listen for motor operation at the front wheel well of the car (same side as the washer fluid reservoir).
If you can't hear the motor, then the motor is likely faulty and requires replacement.
You can operate the front washers to locate where both motors are. (under the car, beside the wheel well.)
If the motor is working but no water is coming out, then remove the rear washer jet and disconnect, then using a high pressure airline, blow backwards into the jet to clear out any blockage. If you don't have a high pressure airline with nozzle, then use something like the nylon filament from a yard brush to poke into the jet, to try and clear the blockage.
Nov 05, 2012 | Cars & Trucks
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
After changing the cartridge the Black in is not working
Your printer's head mainly (black holes) may be block by dry ink. Try to clean it. To clean follow these proces:
Take black ink in a plastic seringe Then unplug black cartrige. See inside into cartrige carrier. There is a black plstic stick. Try it to insert into plastic seringe (carefull). Then push ink through black stick. ( 4/5 times) . After that you will be relive from your printer problem.
Thank you.
Sep 11, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Water will not spray out of the bottom of the vacuum i have checked all the connections and they seem correct.
Hi this is a very common problem, whats happened is the cleaning solution has turned to gel and is blocking the pipe and not allowing the solution to come out what you can try is drain any cleaner out of the container and fill it up with hot but not boiling water and put a couple tea spoons of salt in then leave this to rest for 10min then switch the vac on and try the trigger and see if the water comes out you may need to hold it down for few minutes.
if after doing that its still not coming out then tip the vac up onto its back and have a look at the jets where the cleaner should come out now get a long pin and give the jets a good poke out with the needle doing this should unblock it.
if it dont then its going to need the bottom taking off to get to the hose and so you can squeeze any blockage out but let me know how you get on you may find cleaning the jets gets ot working it does most of the time.
remember when you have finished using it empty the cleaner fluid container and fill it up with warm water then let this run through the cleaner for 3 or 4 min just hold you finger on the trigger and let it drain through the whole vac doing this will prevent it from clogging up in the future
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 27, 2010 | Dirt Devil Vibe Deluxe MCE6680V Bagless...
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
Pump works but no fluid in come to the front windshield. the back work fine.
you need to poke a thin needle into the washer jets to clear blocked jets....or blow them out if pipe is long enough.
Mar 02, 2010 | 2001 Ford Windstar
Water in grounds container
The coffee solenoid valve return side is blocked from dry coffee. You can use cleaning tublets to clean some times the coffee group. With this it might be unblocked if not then you should remove it and clean it with warm water
Jan 30, 2010 | Jura Capresso Impressa S9 Coffee...
Engine not running
Let it dry out a day or so, perhaps in the sun or a warm place. Try again. If it still won't start, try to find a fuel line or fuel jet and inject some compressed air in to blow it out a bit. Good Luck!
Dec 16, 2008 | Boating
Epson Stylus Photo 1290 InkJet Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
