Question about Gbc H600Pro Laminator W Pouch
How do I take apart the case on a GBC H535 Turbo laminator?
2 Suggested Answers
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
I have a GBC Ultima 65 Laminator and the lamination is not adhering. The materials I am laminating are coming apart.
Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Feb 14, 2017 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
I have a gbc heatseal h425 laminator and it wont turn on. Is there a fuse inside the machine that needs to be replaced
Dec 23, 2010 | Gbc HeatSeal H425 Laminator
I have a gbc heatseal h535 turbo laminator that jams, stops rolling, and shuts off randomly.
I had the same problem. It's prob the optical chopper/encoder wheel on the motor shaft that wobbled loose and scraped on the sensor until plastic filings plugged up the holes. remove cover and check the "u" type sensor the chopper wheel runs in. Mine was really crammed full of plastic so I had to take it it off and pick it out with a blade. when you reinstall make sure wheel runs between sensor with no scraping.
Mar 18, 2010 | Quartet gbc RDS1819 Shredder
Gbc H600Pro Laminator W Pouch Logo
152 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
