Question about Konica Minolta magicolor 2430 DL Laser Printer
I have a Magicolor 2430 DL which has worked great for the last few years that I have had it. But now it has a vertical white line through all of my documents and pictures. What can be causing this?
    Guru:
  • 352 Answers
Hello
This issue is caused by the drum starting to fail. the Drum is what transfers the Toner to the paper and when it fails will cause streaking, lines and fading issues.
I hope this helps Regards GM
Posted on May 28, 2011
  • Charlie Goodspeed
    Charlie Goodspeed Feb 15, 2014
    Maybe not - If you open the top, remove the main drum and look straight down past the color cartridges, you may see some toner on the laser window. If so, carefully wipe with a chamois/lint free cloth.
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
I get several vertical white lines in my prints.
Do you have enough ink in your printer? This can be a problem. A faulty drum/roller could also be a cause which in that case will need to be replaced. Since you have done your part i guess the rest should be handeld by an expert personally.
good luck.
Jul 04, 2010 | Konica Minolta magicolor 2430 DL Laser...
Printer leaves two white lines when it prints.
I had a similar problem with my 2430DL only with one fairly prominent white line instead of two. I read troubleshooting tips in manual for this problem and first suggestion was to wipe laser lens clean with a soft cloth. I did this and no more white line! If you do not have your manual please email me and I can forward you PDF manual. syberspirit@yahoo.com
Nov 06, 2009 | Konica Minolta magicolor 2430 DL Laser...
Vertical blank line in printing
Problem 1:The laser lens is dirty.
Solution: Clean the laser lens.
Problem 2: A toner cartridge may be defective.
Solution: Remove the toner cartridges with the color causing the abnormal image. Replace it with a new toner cartridge.
Problem 3: The drum cartridge is defective.
Solution: Remove the drum cartridge and check for damage. If it is damaged, replace it.
To get help with cleaning copy and paste this link into your internet browser window:
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2430DLUserManual.pdf
Wait for the pdf to load.
Then go to page 78 of pdf. Cleaning instructions are written with diagrams.
Do give my solution the highest rating if it solves your problem. Thank you for using fixya.
Aug 07, 2009 | Konica Minolta magicolor 2430 DL Laser...
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical lines.
pleas take a closer look at the pc drum and transfer belt, if there are also stripes then you find a problem, stripes on pc drum means new pc drum and on TBU there is possible to clean the cleaning unit but not in every case. if cleaning doesnt help new TBU
Sep 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
White Lines
My magicolor 2430 dl prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
jim
Jan 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
373 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
