Kenwood KD 3070 turntable
The tone arm will not raise up to return to the arm rest. It skids across the record when returning. I believe the tone arm rest should raise up upon return, but it doesn't. The lever to raise and lower the horizontal bar works when the lever position is chnaged. I believe the horizontal rest should raise when the tone arm reaches the center. How can I adjust for this? Thank you for any response to this.
  • 515 Answers
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Sep 13, 2008
  • Jacqueline H Diaz Jul 26, 2013
    I have tightened and loosened the set screw perhaps 100 times and cannot get the arm to unlock. There's a black plastic, approximately 80 degree, arc that is restricting the movement of the arm. I'm not even sure it was put there in order to lock the arm or whether it actually belongs there.
Will load record arm will come down and start to play then rejects it
On some turntables, there is an adjustment for this. Typically, you turn a small screw to tell the turntable when to return the tone arm to its rest. You might have to look underneath the unit to find it.
May 13, 2016 | Audio Players & Recorders
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Jan 16, 2009 | Technics SL-BD22 Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Sep 08, 2008 | Kenwood KD-291RC Turntable
1,288 people viewed this question
 Grubhead
Grubhead
