Question about HP PSC 1315 All-In-One InkJet Printer
Printer will not print.a photo paper went thru on a angle. now it will not print.
  • HP Master
  • 32,281 Answers
A paper jamb could be caused by dirty orsticky rollers, also failure to remove all traces of paper from a previouspaper jamb.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.
Try cleaning the rollers with methylated spirits
Posted on May 28, 2011
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Jan 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Nothing prints on paper
Kodak printer 5500 make out photos with UltraPremium Paper very flashy even with darker photos shots,
tried calibrations with photo paper kodak says: no suitable paper format
Feb 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper going thru at an angle and jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Printing problem
Did you adjust the paper guide on the paper feed side?
Lou
Sep 01, 2008 | Epson Stylus Photo R300 InkJet Printer
Canon i470D...code 302 (paper Jam) shows up on the digital screen. There is no jam. When this happended the document printed, but while printing reversed it self(paper went backward) then went properly...
I had the same problem. I took a card stock sheet of paper. When you turn the printer on and it trys to take the paper thru, I forced it thru and had some small pieces of paper come out. I had the front open so I could see what was happening. It fixed mine, hope it helps u.
May 06, 2008 | Office Equipment & Supplies
Printing photos
That is called pixelation and is usually the result of enlarging a photo, whether it be resized larger on the computer or printed at a larger size than it's original pixel dimensions.
Check your printer settings for a setting like "resize photo to fit paper" and uncheck it. Or print from a photo that is larger than the paper and it will reduce the size without any pixelation.
With digital photos you can always go smaller than the original, but rarely ever larger.
Feb 17, 2008 | Epson CX8400 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
