Question about Sony Cyber-shot DSC-S750 Digital Camera
My flash stopped working - Sony Cyber-shot DSC-S750 Digital Camera
  • 122 Answers
There is a little function to switch it on and off. The button has a small lighting sign. Now put the camera on automatic ( green point) and foto into the night. If the flas h does no go of on automatic its broken.
Please take the battery out and put it back in before testing this
cheers
rene
pls add kudo's if solved
Posted on May 28, 2011
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
The flash works when switch on then stops
Sounds like faulty flash capacitor, This is not a user fix, needs to go to shop.
Sep 22, 2012 | Kodak EasyShare M530 Digital Camera
Flash 380EX with EOS 40D and 18-55 Canon lens. At all zoom positions under 55mm the flash is too weak and the pictures are underexposed. At 55 mm flash works fine. Pushing "*" button does NOT...
You may need to adjust the flash exposure compensation about 1 stop or try 1 stop and if it's still not enough go a stop and a third. What's happening is the flash is being dispersed over a much wider field of view and the fall off is so much greater then at 50mm which the beam is narrower. The 380 EX works well from 35mm through 135mm. After that it still works if you are in close say 20 to 30 feet.
May 02, 2011 | Canon 380EX TTL Flash
Flash will not work
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead.
May 30, 2010 | Canon PowerShot A590 IS Digital Camera
My 2GB Lexar flash drive has stopped working. It
A flash card wears out every single time you use it. Yours has just reached its end of life - it's dead. Replace it.
May 06, 2010 | Lexar Professional High-Speed 2GB Secure...
Flash stopped working
Jan 05, 2010 | Canon PowerShot A590 IS Digital Camera
Turn signal lights stop working. Neither the right or left turn signal work. Heard a noise before it stop working. The flashing started slowing down and stop blinking. Now it doesn't work at all. What
most likely its the turn signal relay. which is under the hood. in the fuse box. also make sure ur running lights are working if they are connected to the turn signal.
May 08, 2009 | 1993 Nissan Pathfinder
Fujifilm FinePix 3800 flash will not work
Normally when the flash stops working it is because the capacitor the camera uses to store the flash power ( that is what charges..not the bulb) burns out. This is a very difficult repair and should only be completed by a camera technician.
If the repair is over 10 dollars I would suggest a new camera.
Jan 28, 2009 | Fuji FinePix 3800 Digital Camera
The flash isn't working
might be obvious, but try replacing the batteries. also during continuous shot mode, flash will be automatically set to off. otherwise contact samsung for repair estimate. Good luck
Mar 13, 2006 | Samsung Digimax A6 Digital Camera
Sony Cyber-shot DSC-S750 Digital Camera Logo
147 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
