Question about Proview PX 770A (White) 17 in.CRT Conventional Monitor
My hp cpu wont turn on vectra-vl240mt wen you push the startup button
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
The system fan is missing or is not working your system has been halted in order to avoid any dammage your system will power down after 3 seconds for hp vectra vl 420 plz help
If you're referring to the fan on the CPU , and it does not run when you turn on the computer , yes replace it. The system is protecting the CPU from overheating . If you're not sure if the fan is bad , remove the computer access cover to the main board , then , turn the computer on and see if the CPU fan starts to spin. If you notice the fan blades vibrating or jiggling but not spinning , then replace the fan motor assembly .
Sep 20, 2010 | Computers & Internet
Hi everyone, I have HP Compaq6910 notebook. The problem is that when it start windows it was too slow. It will take almost 3 minutes to display the Windows loading bar and another 3 minutes to log in to...
Sounds like you have to many startup programs. Check msconfighttp://www.liutilities.com/products/wintaskspro/processlibrary
Don't download or scan anything they ask but it tells what each processor does so you can manually check which ones you obviously don't need and then uncheck them and choose selective startup.
Your boot time will be much faster. Obviously you want all the neccessary startup files to boot so only uncheck the ones you know you don't need at startup.
I think thats why your screen takes so long to boot.
Nov 14, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Bios defult to erase system passowrd
You can only change supervisors password in BIOS by entering blans(spacebar) to reomove that password but you cant change your windows password. For that you will have to login with a different user and then delete/change the earlier password. Other repair the OS from its original disc and make sure where you enter the passwords....Do not try to add supervisor password in BIOS, thats very deceptive....sodeep
Mar 20, 2009 | HP Vectra VL400 PC Desktop
CPU is locked!
remove the battery from the unit and allow it sit for a couple of minutes then plug in the unit to power and see if it somes up. Removing battery and power often unlocks a unit. make sure hibernation is not causing problem. Once it comes up successfully, power off and reinstall the battery, try again. Some times a failed/failing battery can lock things
Jan 06, 2009 | HP Vectra VL400 PC Desktop
Xbox 360 tray wont shut
u can give the tray a little push and see if it moves in, i know someone else who had the same problem, if you cant play games the laser reader may have died on you
Dec 26, 2008 | Microsoft Xbox 360 Console
Hp vectra vl wont start xp, keeps trying to start over
Could you explain what are you booting from if like you said "no disk drive on this". What was the last thing the member of your family does on that PC? Any new installed programs, or hardware? Does the PC restarts itself after that "full circle" or stays frosen?
Oct 23, 2007 | HP VECTRA VL PC Desktop
Proview PX 770A (White) 17 in.CRT Conventional Monitor Logo
20 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
