Question about Opteka Home Security
My Opteka digital picture frame has suddenly stopped displaying pictures. Power is on - there's a periodic "ticking" at about 0.5 Hz, that sounds like it's trying to access a hard drive. There's also a green light that brightens in time with each tick. I unplugged it overnight but that didn't help. I play the pictures off a USB stick, and haven't changed that recently. It was working fine for months, suddenly stopped for no apparent reason. Any suggestions?
  • 1139 Answers
SOURCE: Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Posted on Jul 14, 2008
  • 280 Answers
SOURCE: Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Posted on Jul 25, 2008
SOURCE: Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
Posted on Apr 05, 2009
  • 9 Answers
SOURCE: Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Posted on Jun 22, 2009
  • 1684 Answers
SOURCE: x2 MW19R is ticking and no display?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details or if you have any questions.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Aug 13, 2009
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
Oct 24, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
Will not display larger file size pictures from my new digital camer. The digital frame is model DPF-1021. From our old digital camera, the file sizes of pictures wer under 200KB. The new camera produces...
No you simply MUST have the pictures in the EXACT format & size that the Frame uses...You can simply re-size the pic's Usually they are pretty picky what they run... usually it will be a set format.. say JPG, and size say 200KB and color depth say 24/32bit. If one uses anything else your are going to get problems.
Go here to get a free good image resizer, download and install, then all you do is right click image and resize.
Jan 31, 2010 | Westinghouse DPF-1021 Digital Picture...
Kodak EasyShare EX1011 Digital Picture Frame
Probably a loose cable or a problem with the circuits
Oct 18, 2009 | Kodak EasyShare EX1011 Digital Picture...
Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
I have a Brookstone digital picture frame that stopped working
I have encountered this same error on the frame I bought 2 years ago. I saved the pictures to a backup and then reformatted the frame - this didn't work - does anyone have any other solutions???
Home Security Logo
54 people viewed this question
Top Opteka Home Security Experts
Lawrence Oravetz
Are you an Opteka Home Security Expert? Answer questions, earn points and help others
