Home Logo
Posted on May 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a wiring diagram for a 1/2 HP 220V flotec water pump please. Can't find one any where.
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on May 28, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824284
Points
9577
Here you go hope it helps Tim:
http://www.depcopump.com/datasheets/flotec/FP2100_series,FP2200_series,FP3100_series,FP3200_series,FP3300_series_manual.pdf
Pentair Flotec 1/2hp Well Pump. How do I wire a new start capacitor to it please?
Question edited for clarity.
Wow, no water for a week! I can't begin to imagine how difficult that is to cope with.
This is a good site
https://terrylove.com/forums/index.php?threads/need-wiring-diagram-verification.62234/
Lots more here and also on the images tab
https://www.google.com/search?q=flotec+1%2F2hp+well+pump+%22start+capacitor%22+wiring+diagram
The Flotec pump has a model number, and it would be good to Google
Flotec (model) replace start capacitor.
All problems can be solved via Google.
Good luck.
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Wiring diagram
??? THIS PUMP COMES COMPLETE WITH A THREE PRONG GROUNDED PLUG ON IT'S END , NOT SURE WHAT YOU MEAN BY "WIRING DIAGRAM" IT JUST PLUGS IN LIKE ANY OTHER APPLIANCE DOES
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
1helpful
2answers
I have a 1 month old Model FPOS1775A Flotec pump. The discharge hose is 3/4 inch with a level run of 20ft.It pumps water but only at 2 and a half minute intervals even when fully submerged!!! I now have a...
If the pump is only pumping for a few seconds at a time it may be a problem with the control board. On two of mine, the 10mf 100v smd capacitor came loose. Resoldered and potted with hot melt glue. One of them is working with the other yet to be tested. Don't recall what the exact symptoms were, only that it wasn't continuously pumping water while submerged.
Unit is oil filled so should be dismantled in the upright position.
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
