Question about Hoover Vacuums
Hoover S3670050 how do I open the unit up, to replace a cicuit board?
Where can I get a mother board for a Freejet 3in1 cordless hoover model FJ180WB2
probably need too replace the whole board. safest way in case board is at fault. Appliancepartspro.com with model no.
May 02, 2016 | Hoover Vacuums
No power to hoover s3670 canister vac
either need a new motor or speed control board.
Mar 27, 2013 | Hoover S3670 Bagged Canister Vacuum
Fitting new motor to Hoover ducted CV300CN
i opened it up quite easily, attempted replacing brushes, didnt fix the problem so about to order a whole new motor.
Dec 20, 2012 | Hoover Vacuums
The filter chamber, pleated filter, and lid of my Hoover fold-away U5163-950 was accidentally thrown out. Can I replace it? The vacuum is still working well.
You should have no problem replacing the items noted. The below information was located in the "Service" section of the manual for this unit (found here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052463.pdf). The manual also has extensive information describing your unit.
To obtain approved HOOVER service and genuine HOOVER parts, locate the nearest Hoover Factory Service Center or Authorized Hoover Warranty Service Dealer (Depot) by:
• checking the Service section of The Hoover Company on-line at www.hoover.com OR -
• calling 1-800-944-9200 for an automated referral of authorized service outlet locations (U.S. only).
Mar 09, 2011 | Hoover U5163-900 Upright Vacuum
My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
I HAVE A HOOVER SAVVY AND THE BRUSHS WON'T TURN.
there is a small circuit board right above the motor on the base ,look and see if there are any burn marks or discoloration.if the headlight isn't working either then thats the problem .the circuit board.you can get it through all-type vacuum and janitorial 314-275-8006 supply.$18.49.there is a belt that runs up the center from the roller to the geart on the motor
Apr 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
112 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
