Question about Electric Drills
The local (very reliable) drill repair shop said my Westcraft 549 drill had a broken wire in the winding, and they did not know anyone who could re-wind the core. It's the first drill I ever used, 50+ years ago, and I'd like to see it working again. Any thoughts? Thanks.
  • 3,053 Answers
I would check with local starter rebuild shops. It is basically the same concept.
Posted on May 28, 2011
I have a 2003 Ford Ranger 3.0 and I have an exhaust manifold bolt that has broken off inside the manifold,and the evaporator coil,and other AC parts are in the way .what options do i have on this
With the exhaust manifold off. If there is some of the bolt sticking out. You'll need a torch to heat the head up, red hot around the bolt. Also a pair of needle nose vise grips to grab it with and turn it out. You'll have to heat it several times to get out. No bolt showing, you best bet it to pull the head. Drill the bolt and extract it.
Jul 26, 2016 | Ford Cars & Trucks
Westcraft. Where can I get a manual and assembly diagram?
[PDF]Operating Instructions and Parts Manual Drill Press
https://www.northerntool.com/.../manuals/12...
Northern Tool + Equipmentour Authorized Service Centers located throughout the United States can give you quick service. ... HOW TO GET SERVICE ..... Exploded View Drawing JDP-15M/MF . ... If you are not familiar with the proper and safe operation of a drill press, ...
www3.nd.edu/.../Jet%20Drill%20Press%20JDP...
University of Notre DameCompletely read the safety and maintenance instructions before operating or servicing the machine. To obtain maximum life and efficiency from your JET Drill Press, and to aid in ... Authorized Repair Stations located throughout the United States can give you quick ...... A spindle speed and pulley/belt arrangement chart.
[PDF]Operating Instructions And Parts Manual 17" Drill P
Dec 18, 2015 | Drills
Makita 451 stopped working NO smoke but liights still work?
Things I've run across in my shop to check for:
1. Is power getting out of the switch to the motor. It is possible for the part that powers the light to work and not the part that goes to the motor
2. Is the armature jambed by something that doesn't belong in there so it can't turn.
3. Is the armature burned up. Check the wires for burn spots, broken wires or discoloration of the windings, they should be the color of a new penny.
May 22, 2014 | Makita 18V LXT Lithium - Ion Cordless...
Was drilling a 1" hole the drill got hot and
Motor coil windings burned out - take to repair shop or buy a new one
Feb 15, 2011 | Dewalt 18 Volt Compact Drill Kit
I have an old Black & Decker twin blade electric mower that just died. I took apart the motor and it looks pretty dead, I think a short in the windings most likely, but the brushes are worn out and the...
find your local electric motor repair/rewinding shop and take the old motor there
ask what you could get to replace it
consider that the new motor will probably be better if it is a bigger hp unit as grass ( especially wet grass) is hard to cut and B&D would only install a motor that only just does the job
Mar 12, 2017 | Black & Decker 18", 6.5a Electric Mower
Hilti-284228-rw-98091-163317
to my knowledge you have to send it to a hilti service center. you can't buy parts nor can a local shop buy parts for them. you may just have a loose wire or the switch you move to change direction may have come loose inside.
Apr 13, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
My gsc r3o quit working, battery is good but it will work as long as I have the dc adapter plugged in...I need to find a reliable repair shop...
if its work with the adater its should work
with the battery pack may try a new battery
if it not check the battery contact, some one comme
corroded very fast or broken if not
bring to your local repair shop its a singular problem...
Feb 09, 2010 | Toshiba GSC-R30 Camcorder
Can the battery compartment be repaired? the metal section at one end of the compartment has come off and has been lost.only one end of the battery is now touching element so their is no power getting...
Sometimes this can be repaired by trying to solder a piece of wire onto the broken end & making sure it is wide enough to make battery contact. It will depend on how much of the broken piece remians so that you can get a good solder connection. Try & enquire at a local repair shop or computer shop to see if they have any old or non-working mice that are being discarded & then just use the battery terminal from there, it will be more reliable longterm.
Sep 02, 2009 | Sony VGP-BMS5P/B VAIO Wireless Bluetooth...
10-32x1 Left Hand Chuck Screw for Milwaukee Magnum Holeshooter
any reversible drill will have the lh screw in the chuck
cruise the garage sales, dump shops etc and get a dead drill and remove the screw
could be phillips head or hex head but that will not matter
if you have access to a quality bolt retailer ( not a hardware shop) they will have the screw
go to an appliance repair shop that repairs drills as they may have a dead drill with the chuck still attached
Apr 04, 2017 | Milwaukee Drills
Power cord on DeWalt electric drill
dbx is a family of noise reduction systems developed by the company of the same name. The most common implementations are dbx Type I and dbx Type II for analog tape recording and, less commonly, vinyl LPs. A separate implementation, known as dbx-TV, is part of the MTS system used to provide stereo sound to North American and certain other TV systems. The company – dbx, Inc. – was also involved with Dynamic Noise Reduction (DNR) systems.
My conclusion is that your answer was right on.... good work.
Jan 30, 2009 | Saws
Drills Logo
59 people viewed this question
Top Electric Drills Experts
Are you an Electric Drill Expert? Answer questions, earn points and help others
