Question about Epson LX-300 Matrix Printer
SETUP FOR LX300+ IN REDHAT 9
I HAVE INSTALLED RED HAT 9 , I HAVE PRINTER LX 300 +
how can i setup this print , i try to set it , but when i m giving print command , it will print 2-3 charcters and skip the whole page , same on second page
pls help me , how to setup the printere
thanks
Change the port setting at bios . change lpt port setting in bios ,
Posted on Nov 10, 2008
I want also solution about this problem .
if u have got soluton tell me
i am using opensuse10.2 os
plz tell me solution,
Posted on Oct 29, 2008
My epson lx-300 printer tear off is now off so i want on this fucation . plzz tell me soluation . i want reset my epson lx-300+2
1. In the Finder window, click on Go on the Title Bar and select Utilities.
2. Open the Printer Setup Utility.
3. Click on Printer Setup Utility in the title bar.
4. Select Reset Printing System.
Jan 27, 2011 | Epson LX-300 Matrix Printer
Give steps to install redhat on pc
Redhat ... all installation guides are almost same, but before setting up installation make sure you have no critical data on you drive. You might end up setting it up on wrong drive or complete partition leaving you with erased data.
No worry, if new system or virtua lsystem
The following link for Redhat Setup
http://www.zdnet.com.au/red-hat-enterprise-linux-5-3-screenshots-339294769.htm
May 23, 2010 | Red Hat Enterprise Linux ES Basic Edition
Printing on a customise continuose paper
Check the printer settings about page length by the procedure given in the user manual.
If OK check your software if it is giving soft commands to adjust paper lengths.
Sep 28, 2009 | Epson LX-300 Matrix Printer
My epson LX-300 printer got wrong. it's printed strange character seem wingdings character. i used continous form, LX300 pulled the paper over n over. pls tell me how solve it tks
either corrupt drivers, or bad print head. Try reinstalling the drivers for the printer. Otherwise, the problem will be more expensive to fix then to replace the printer.
Apr 30, 2009 | Epson LX-300+ II Matrix Printer
Epson LX300 page print problem
the page length is not properly set.
Refer your user manual and set the proper page length.
Feb 10, 2009 | Epson LX-300 Matrix Printer
Prints on the sides only and not in the middle
it print on the sides only even though the paper is fitted well give solution to solve this problem
Dec 19, 2008 | Epson LX-300 Matrix Printer
Printing shows doubling
alguien por favor envieme los drivers de la impresora EPSON LX300 les agradesco
May 26, 2008 | Epson LX-300 Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
May 26, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
192 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
