Question about ASUS A7V8X Motherboard
IMPROPER SHUTDOWN OF DESKTOP PC
Improper shutdown of pc after a few seconds upon switching the power button.No message beeps or warning."installed or reinstalled new cpu and cpu speed choices" always appear. Already replaced power supply w/ 350W. Bios wont save the settings made after choosing the "save and exit" .Loaded all the default settings in the bios,cleared the CMOS.Pulled out and re-installed all hardware connected to the motherboard.Model:ASUS A7V8X-X
  • 781 Answers
1st Try some different memory
2nd Try this remove all attachments to M.board hard drive cd dvd all except for memory and video card and try to boot
if it does install removed item one at a time and reboot and so on until you perhaps find faulty item
Check all cables to hard drive and
cd dvd are connected properly
Red or Blue stripe nearest the 4 pin power lead and they are set correctly master and slave etc
Posted on Aug 17, 2008
How to activate auto chkdsk after improper shutdown
To do that:
1. Click Start button
2. Click Run
3. Type CMD
4. Type "chkdsk/ f" at the command prompt
CHKDSK Starts when Windows restarts from an improper shutdown.
Chkdsk is part of Windows - it is a utility to analyse and fix HD errors.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Computers & Internet
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
Click START
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Rich
Dec 12, 2009 | Dell Inspiron 1525 Notebook
When I shutdown my computer it restart by itself but my screen stay off and I need to unplug the computer to restart it Emachine T3065
Press POWER button on your keyboard.(if it is given) OR make sure that your PC doesn't have any improper installation of any software.
Oct 15, 2009 | E-Machines eMachines Desktop PC
"Improper Shutdown" - Printer keeps turning on and off.
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
8. Be patient to let printer run its tests.
Sep 12, 2009 | HP Photosmart C6100 All-In-One Printer
Printer cycles on/off and displays "improper shut down"
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Impropershutdown
Press 6 and # while disconnecting the power cord (wait a little bit) and connecting it again. When the display is turned on again you can release the buttons.
After this reset you need to enter language, location and any wireless settings etc.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Improper shutdown
Load and run this tool.
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
Try and shut the pc down and see if anything is working hard or just not shutting down.  Take alook at the error logs and see if there are any error messages.
Load and run spybot from http://www.spybot.de
May 28, 2009 | Lenovo 3000 Y410 Laptop
Stuck shutting down
Press and hold the power button for 10 seconds and then release it. This will shutdown the laptop regardless of what state it is in. If it still doesn't shutdown then disconnect the laptop from the powersupply and remove the battery. Note that this will count as an improper shutdown. After it shuts don put the battery back in and you should be able to power it up.
Feb 03, 2009 | Computers & Internet
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
ASUS A7V8X Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
