Question about LG LP1200DXR Portable Air Conditioner
I have this model and I am trying to get the hose onto the unit and it wont stay on, what do I do?
    President:
  • 3,074 Answers
Use a hose clamp, this will keep it on Tim
Posted on May 28, 2011
Whirlpool duet model gg9250p wont run when its humid out and the damp light glows dimly,,try it on a drier day and it runs fine
Do you have this model down in your basement where the humidity changes according to the outside weather?
You can try a fan blowing onto the model to circulate the air around the unit. Good Luck Friend.
Oct 11, 2017 | Whirlpool Dryers
Paid for maps wont download
Contact Garmin directly and ask for a CD version to be mailed to you.
Feb 26, 2014 | Garmin zumo 550 Motorcycle GPS Unit
Hoover steam vac hose is broken
This applies to Hoover SteamVac model F5899-910.
My unit had a broken hose. I repaired the hose using duct tape and Teflon tape. The breakage seems to be due to a manufacturing error or design defect. The hose is clamped to the unit where it passes to the inside. The position of the clamp did not allow enough slack when the handle is released and the unit is wide open.
The hose coupling has a plastic latch that holds it onto the vacuum nipple. Pry it and remove the coupling. Then trim the ragged end of the hose and clean things up. Wrap the hose with some teflon tape and then tape the hose to the coupling with several turns of duct tape. Attach the hose coupling back onto the vacuum nipple.
Now you should move the clamp say an inch, so that it leaves more slack. Take the two screws out of the clamp and pry out the plastic bracket/cover that holds the clamp in place. Then move the clamp and screw the clamp back onto the bracket/cover. Then snap the bracket/cover back in place.
Take care not to put too much slack in the hose (by moving the clamp too far), as the hose can also bunch up due to being too crowded when the handle is upright.
Inspect the hose and the tape whenever you use it.
Aug 03, 2012 | Hoover F5899-910 SteamVac Vacuum
Where is the drain hose that I need to remove to change the oil on an 883 2001 Harley Davidson model
The drain hose location on the Sportsters seemed to have changed every year. But, they stayed in an area just below the battery on the right side of the bike. The hose may simply plug onto a frame tube down by the swingarm. Sometimes they came off a "tee" right behind the primary case.
Good Luck
Steve
Mar 21, 2011 | Harley Davidson XLH Sportster 883 Hugger...
Wont stay running keeps shutting down
sounds like it could be a pressure switch try hosing off the out door unit cleaning the outdoor coils will lower the head pressure just don't flatten out any of the coils with high pressure water hold the hose back a bit and try brushing with a wire brush gently . with out more info this is really all i can offer .
Nov 16, 2010 | Heating & Cooling
Water not going into hose or bucket
where are u located and where aqre u using the unit
a dehumid wont work properly below 60 degrees
or 40 percent humidity
Oct 17, 2009 | Goldstar DH304 Dehumidifier
I have a model HD-306 Haier dehumidifier which is hooked up with a hose to a drain. It has been working fine until several days ago. Water now is coming from the bottom of the unit onto the floor. I...
please make sure the unit is leveled.also make sure the hole in the drain pan not clogged.also the size of the hose must be fit the hole not smaller
Sep 04, 2009 | Haier 45-Pint Dehumidifier
Windchaser portable a/c hose that connects to back of a/c model # pacr 10
the hose in the back of the a/c unit will not stay connected to the out flow at the window. Wind Chaser PACR 10
Jul 16, 2008 | Heating & Cooling
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
LG LP1200DXR Portable Air Conditioner Logo
81 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
