Question about Denon AVR-600 Receiver
How to I reset my AVR 600 when protection is on?
    Brigadier General:
  • 8,546 Answers
Resolve the reason it's seeking protection.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 28, 2011
Testimonial: "Thank for your added direction regards Zak"
  • 1 more comment
  • zakstorm620 May 28, 2011
    It doesn't answer a simple answer of how do I reset. This is the first time the protection has come up and I have nothing attached to the amp. Please if you know how to reset the avr 600 that would be helpful information.
  • David Dunn
    David Dunn May 28, 2011
    If you have the manual it might be in there as are most answers to fixya requests. I can't find it even at the Denon site.
    Cool thanx Dunnbiker much appreciated
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Why do the words 'Auto Protect' come on to the screen when I turn the reciever on?
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 24, 2011 | Denon AVR-600 Receiver
AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Dec 01, 2009 | Harman Kardon AVR 130 Receiver
Protection mode
The protect mode with nothing connected indicates that the output transistors for one or more channels are shorted. These will need to be checked and replaced. This is a simple repair for an experienced audio shop, Figure about $10 for each output transistor and add in another $10-$15 for misc parts that may also be smoked.
Dan
Mar 18, 2009 | Denon AVR-3600
AVR-600
The problem is past that point once the protect continues to activate the amp is in need of service
Feb 25, 2009 | Denon AVR-600 Receiver
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Says protect
Probably some speaker wires got shorted or the output stages freaked out and the cpu went into protect mode. Normally plugging it out of and in to the wall socket should/could reset it.
First check all wiring at the speaker outputs and on the speakers
then if it still wont startup you could try the avr-1500 method with
some trial and error pressing of buttons.
avr-1500 reset method:
Unplug the unit from the wall, hold down both video select and audio select at the same time, plug it back in. Keep holding both buttons for 2 secs, unit will reboot. As you have no audio select button on your avr-1100 you might try pressing video select and another key to see if this will reboot it.
Jan 13, 2008 | Denon AVR-1100 Receiver
Protect sign is on a avr 900
I have simillar problem. Can you remember what was the last thing you did with it before the problem come
Dec 05, 2007 | Denon AVR-900 Receiver
718 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
