Question about Broan-NuTone RC515 Door Chime Remote Control
Repair at home
I have 4 of your Broan RC515 since 2006 and they all work. One started making a buzzing sound from the speaker which means one of the filter capastors is geting weak and alowing 60HZ to go through. I took it apart and found nothing looking in bad shape. I have electronic understanding but instead of replacing one cap at a time I will just ask you which one would be the most likly one to do. If you can send me a schematic and I will find it my self. Thank you, Robert J Cavasos. rjcrepair@eartklink.net
  • rjcrepair Aug 16, 2008
    using this esr tester while all caps are still connected to the CB won't work will it?
    Thank you for your info. I don't intend to buy a $200 ESR tester just to fix one door bell. I will just buy a new one when this one quits. However if you would send me the schmatic diagram I will be able to pinpoint the most likely and work my way through all one step at a time.
    Problem Solver:
  • 6 Answers
You Need to Buy a ESR Electrolytic Capacitor Tester. Can get one on Ebay ( Affordable ) or Shop around. I Bought one New when I was a Troubleshooter & Making A Lot of Money for abt $200. Largest paper or Metal Electrolytic Capacitors are usually Your Main Problem. Elect Caps Dry out from Heat-age. Capacitor Testers DO NOT Find these Problems I Tried them. More Often I always find More than One Bad ESR Electrolytic Capacitors on All Audio, Intercom, Computer Monitors, Color Tvs I Service. The two leads You put across all Elect Caps on Motherboard or Chassis Instantly Tells if good-bad. I Make and Save Money on all Products I Often service with ESR Problems. Esr Tester Pays for itself Quickly. Takes Disassemly and time to Restore Service But I always Get the Job Done.
Posted on Aug 16, 2008
  • Jack Emery
    Jack Emery Aug 17, 2008
    The ESR Tester is Made and will work IN Circuit. No Unsoldering. It Finds all Bad ESR Caps. Don't have Circuit. I Fix almost everything without a Schematic when its Bad ESR Caps. Bending, Weaving, Hum are all the Symptons. OverHeating of Semiconductors & Tubes will Happen with this AC Ripple NOT Being Filtered. If You Locate the Low Voltage Power Diodes Look for a Large Electrolytic Cap Near them or trace wires. 2 Clip Leads and a Replacement Electrolytic Cap can Be Paralled across a Large Questionable Cap with the Same Value or Voltage or in the Ball-park on Capacity. Do this Unplugged. Lo & Behold when You Plug it back in Hum May be Gone. Then Unplug Mount and solder Replacement. I'm Sure You can get a ESR Tester Very affordable & Reasonable if You Shop Ebay-Ham Radio Clubs at the School.
SW-910, blown speaker or ? makes rattle/buzz sound. replace speaker and/or change to passive type sw?
i would suggest replacing it rather than fixing. The cost of the repair will be about the same.
if you went to a passive sub/seperate power amp setup you could get a much higher quality unit, but it would cost you considerably more cash.
Feb 01, 2015 | Sony Audio Players & Recorders
Why Is my RCA home theater system making that noise through the speakers it's like a buzzing noise
It sounds like you are getting bleed through from another device...radio, cd player...etc. This is caused by improper grounding. Some where there is a wire not connected correctly or you need to ground the whole system.
Jan 30, 2013 | Audio Players & Recorders
I have a dell inspiron N-4010 14" laptop. I have played some .flv format songs in my VLC player yesterday iwth maximum Computer & VLC Application volume. After some time the speaker started...
Hello
Check your system with external speakers, if it gives same problem its mean that the audio drivers od the system gone corrupt, needs re-installation,
if the system gives the correct sound, means that the speakers gone damaged, need repair/replacement, you can do by your self if you are technical enough otherwise you need technical assistance from Dell Support
Good Luck
Feb 17, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
Buzz coming from speakers. x2 gen 19 inch lcd been working for 2 years on old xp and now win7 no problem with win7 for 4 months before this. checked for updated sound drivers. plugged in usb powered...
Buzzing is usually caused by bad audio ground connection. Try insert and reinsert the audio cable first. It can also be the sound card. Try using the MP3 player as the sound source feeding the monitor, if it still bad then it can be problem in the DC filter caps in the power supply, or bad sound IC in the audio board inside the monitor. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
May 07, 2010 | X2Gen MG19VT 19" LCD Monitor
PS8 Subwoofer started buzzing non-stop
with nothing connected and the sub turned on....Most subs buzz when the circuitry starts to fatigue. The last time I heard this ..the repair ended up being one of the two fat capacitors inside the sub. I have a means of testing this,,you may not. I am a repair shop with a bit of experience in component level board repair.
May 06, 2010 | Proficient S12 Subwoofer
Loud buzzing, but no sound
Sounds like they are plugged into the wrong port on your computer? You need to make sure they are plugged into the Green ringed port on your sound card.
Hope this helps
Cheers
Al
Sep 11, 2009 | Bose Audio Players & Recorders
KEF KIT100 Buzzing
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25. I would replace all 6 on your system. To insure that the other's do not go bad after fixing the bad ones.
Dec 03, 2008 | KEF Audio KIT100 System
Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Dec 05, 2007 | Amana ATB1935HR Top Freezer Refrigerator
Expert advice
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. Used a NTE382
replacement and it has worked fine.
Jun 20, 2007 | RCA RS2640 CD Shelf System
Continous Buzz/Pulse from speakers No other sounds come out
Sounds like you have an open filter capacitor. Your gonna need to look at the b+ and figure out what cap is bad. A circuit diagram would assist you in this repair. If you have no experience with electronic repairs then your gonna need a pro to assist you with this as there are no user replaceable parts inside this unit. Sorry Man. Good Luck
Jun 26, 2006 | RCA RT2250 System
Broan-NuTone RC515 Door Chime Remote Control Logo
289 people viewed this question
Top Broan-NuTone Televison & Video Experts
Electro Med Services...
Are you a Broan-NuTone Televison and Video Expert? Answer questions, earn points and help others
