Need ac adapter model hs 150-24 input ac 100-240v50 output dc 24v 6.0a
SOURCE: BROKEN ANTENNA BROKEN AC/DC ADAPTER
I just started to put some stuff on ebay and I have new one ac/dc adapter Model # ae9512
Good Luck!
silverrockny (my ID on ebay)
Store nameon ebay: The right Stuff Store
Posted on Dec 12, 2007
Kegtapper
  • 94 Answers
SOURCE: COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
After you have verified that the solder is good around the DC Jack >>>>
Check MOSFET (Anachip 4407 or Fairchild 4435) near DC JACK
[replace the pair PNP/NPN]
Check MAXIM IC (MAX1999)
Posted on Mar 31, 2008
VOTIT
  • 2071 Answers
SOURCE: The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Posted on Jun 23, 2008
SOURCE: Input/Output Cord
Try lcdpayless.com
Posted on Dec 17, 2008
  • 33 Answers
SOURCE: durabrand ac/dc adapter model TAD-10
you can buy an aftermarket brand that is the same as the Durbrand ac/cd adapter model Tad-10 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Posted on Dec 18, 2008
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
REPER AC ADAPTER K30263
K30263 Adapter..... is REPER "REPAIR"
CANON K30263 AC ADAPTER 32VDC 0.9A 24V Used POWER SUPPLY PIXMA M
$59.99
Condition : Used
Content : One Adapter only Manufacturer: CANON
Model Number: K30263
Part Number: QK1-2228-000-DB01-01
> Input Voltage: 120-240V~ 0.9A 50/60Hz
Output:
32V === 0.9A
24V === 0.5A
24V === 0.03A
Output Connector Type : 2 rectangle White Flat
1 x 2Pin, 1 x 7Pin [ • • ] [ • • • • • • • ]
Dimension: 17 x 10.5 x 7 cm approx.
Weight: 310 grams approx.
Compatible with: Canon Pixma MP830 Printer K1027 K10270 QC1-9029-DB01-01
http://azsurplus.com/index.php?main_page=product_info&cPath=1_24&products_id=1211&language=en
Feb 26, 2015 | Office Equipment & Supplies
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
How can I operate my LG 26LE5300 LED LCD TV in my motorhome the most direct way possible (i.e....without an inverter)? This low power (40-50 watts) TV has an external brick to convert 120 AC to it's...
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | LG 26LE5300 26 in. LCD HDTV
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
