Question about Goodman GMS90703BXA Heater
What size filter do I use for a GMS8 gas heater? The installer put in a filter that is too large and is hanging out of the side of the heater.
  • Goodman Master
  • 2,464 Answers
Measure how much it hanging out and take this off the size of the filter this will give you the size , try candain tire for filters
Posted on May 29, 2011
I need to know the propane orifice size for a Peerless LUH50A hanging heater When running the unit on a regulated propane tank the heater emits black smoke
ask a qualified gas fitter for the correct jet size and have him position the air shroud correctly to get the correct air /gas ratio for a clean burn
Jan 29, 2017 | Heating & Cooling
I have a large dearborn heater(da-6065e) 65000 btu that I want to convert to propane. I need to know the orifice sizes I need. Most haven't heard of one this large.
there is a site --www.eastwaysales.com>products
that have spares for your heater including propane use spares
try contacting them and seeing if jets are available for propane gas
you could alsays contact a local gas fitter that does conversion from one gas to the other as all it entails is a new jet size ( larger for natural gas) and a repositioning of the air shroud to get the gas air mixture right to get the blue flame
gas fitter should have a chart for jet sizes required for certain gas flows for btu unis
Dec 14, 2016 | Heating & Cooling
Why is the right side of the heater flame higher and hotter then the left side
Combustion needs air mix in the correct proportion to burn efficiently-also gas supply may be stronger on the outlet side of burner causing an imbalance-chech for obstruction in either area-cheers Denny
Oct 11, 2013 | Vanguard International Blue Flame - Large...
Fuel filter installation
Look for a canister about the size of a soup can. It should be under the car. There will be a line going in and a line going out The nut size on the canister should be 13/16 and the nut on the lines should be 5/8. When installing the new filter look at the filter!! one side will say "in" the other will say "out"Install the line from the tank to the "in" side of the filter. NOTE! The fuel system will be under pressure be careful when breaking loose the lines gas will spray out. The old filter will be full of gas and will leak so put a pan under the filter before you take it off.
Mar 11, 2013 | 2002 Pontiac Sunfire
I have a GMS8 furnace and it will not kick on.. No heat coming out of heater vents..
Is inducer motor running. If not change it. If it is then remove vacuum line from it and blow through the line on start up. If this works change the pressure switch. If not start jumping the sensors around the burner until you find the bad one
Jan 23, 2013 | Goodman GMS90703BXA Heater
Laars N G pool heater keeps shutting off then restarts
check gas pressure and the size of your line if too small a line and too long a run from the meter it will run out of gas in line then line fills back up heater fires and drains line again
Jul 25, 2012 | Teledyne Laars Laars Lite2 Heater 175000...
Filter for Payne (Carrier?) Heater FB4CNF024??
Yes what you say is right try home depot ,canadain tire, lowes, they all do filters with differant sizes you can get them in 12 , 10 what ever you need
Feb 17, 2012 | Heating & Cooling
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
Need an gms8, control module .goodman furnace
Go to www.americanhvacparts.com or www.furnaceparts.com On the first site type model number of unit upper right corner and pictures of parts will show on screen. Rus
Mar 14, 2010 | Goodman GMS80904BNA Open Flame Mid-Size...
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
144 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
