Question about Maytag PYE2300AY Electric Dryer
Maytag performa pye3300ayw dryer
No light no noise no power! was working fine I check for 220 to unit ok ..
and there is no lint build up? is it time to get a new machine this one was fine last night and still looks new.. i see somthing about thermostat switch
where do i find it? i called someone and they said i need a motor.
  • Anonymous Aug 27, 2008
    no power, no sound, no light, has been fine until this afternoon. checked circuit breaker, lint inside and at outside vent, unplugged and re-plugged. 3 years old.
  • Anonymous Jan 22, 2009
    I have recently acquired PYE3300AYW model of Maytag Dryer used and it was working just fine, then all of the sudden, no power, ....nothing happens when I press the start button. Checked the breaker, even reset the breaker to be sure, still nothing. Any suggestions???????
    Problem Solver:
  • 6 Answers
Check for burnt or loose wires at the junction where the power cord attaches to the dryer. Also check the door switch. When you open or close the door you should hear a click, that usually means the switch is ok. Then open the cabinet top and check for broken wires.Check unit with power off / cord unplugged!!! Safety First. Good luck. BpB
Posted on Aug 16, 2008
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
Taking two cycles to dry one load , the brand is maytag performa heavy duty
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 31, 2011 | Maytag Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer no power
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 13, 2009 | Dryers
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Dryer won't start and smells like something is burning
I'm having the exact same problem verbatium! did you ever figure it out. I already replaced the motor and the belt, but it's still doing the same thing.
Feb 17, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Dryer Mod PYE4500AYW Has power but will not start
check your door switch. if it is ok, get this kit part number LA-1053. This is a very common solution for this dryer. the thermostat fix kit will contain a thermostat and two other parts....one is for gas and the other is for electric. just read the instructions and you will know what one is for your dryer. these parts can be accessed by lifting the lid and looking to the rear of the cabinet past the drum. MAKE SURE TO UNPLUG THE DRYER FIRST
Dec 27, 2008 | Maytag Performa PAV2200
I have a Maytag Dryer Performa Model PYE3300AYW that want run, light does not come on either. Checked Breaker and it was fine, even replaced breaker to make sure, still no luck. Checked thermal fuse and...
Look on the wiring diagram for the dryer. Follow black wire ( + side ) from plug to motor checking all devices in the circuit, also check for any on the white ( - side). Do all tests with the Electricity OFF. Safety first!!! Good luck. BpB
Aug 16, 2008 | Dryers
MAYTAG PERFORMA ELECTRIC DRYER WONT START
Same thing as other owners above...Dryer is five years old and is in need of a good cleaning of lint build-up. Model no. PYET444AZW.
I put a large load of clothes, which probably should have been spun again, into the dryer. When I returned the clothes were still basically wet, and the light in the dryer would not come on, and nor would the dryer start.
Tested the circuit breaker. OK. Tested the outlet with a tester pen. OK.
So in searching the internet for a solution, I found and read this string. Found the fuse, called my local appliance parts store and bought a thermal fuse kit for CDN$48 (incl sales tax). Kit came with three fuses.
Just opening the top of the dryer was a chore for a complete novice. However, the entire top is hinged at the back -- so at the front of the machine, just gently poked a slot screwdriver in the gap ringing the sides near the top, twist screwdriver and lift. Big fuse is easily accessible at the top near the back of the drum. It's a round thing about the size of a quarter screwed into a metal frame with two crimped-on wires coming out the top. One screw to removed the frame. Then detached the crimped-on wires, and removed the fuse from the frame with two more screws. You will need a smaller size ratchet or nut-driver.
While you have it apart you might as well change the second nickel-size fuse, too, although it is more of a pain.
You have to remove the coiled elements, which are basically just big springs. They come out with one screw on the right and a little finesse. The second fuse sits on the right-hand side of the metal box surrounding the coiled element. The screw for the coil also held the frame for the fuse in place, but the frame will still be secured to the box with a couple of small tongues. So you will still need to kind of lift and pull up on the frame housing the fuse. It requires some patience and finesse. Remove the crimped-on wires, and change the fuse.
Of the two smaller replacement fuses that came with the kit, there was one marked for a gas dryer and another for electric. (The big fuse was good for both.)
Then start putting it all back together. Took me two hours in all. But now that I have done it once, it would hopefully take me only 30 mins. now.
Finally, my replacement instructions suggested cleaning out your machine and removing the lint and other burdens which probably overloaded the fuse in the first place. So I bought one of those specialized lint brushes to clean out the trap and the exhaust hose and vent.
Sep 25, 2007 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
570 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
