Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
The oven will not light -- I can smell gas and there is a loud burst but no flame. The stove burners do work, however.
  • Frigidaire Master
  • 5,568 Answers
With the oven door open, watch the vents at the sides of the floor of the chamber for an orange glow a few seconds after you try to turn the oven on. If it doesn't appear and is similar to other later ranges, it means the igniter has failed. If built as others, it will have hot-surface igniters (one down, one up) and the lower one has failed.
To confirm that this does use the common system, air out the oven first then try the broiler. If it works, you have gas available but nothing to ignite it. Also, you should never get even a distinct thump; this could be dangerous and the gas should not flow without lighting for more than a few seconds.
Posted on May 27, 2011
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
The ignitor in the stove heats up, but we don't get a flame in the oven. The burners and broiler work fine. What's broken?
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Maytag PER5710 Performa Electric Kitchen...
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
337 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
