Question about Microwave Ovens
Turntable stopped rotating. Switch light still comes on
  • 1 more comment
  • raycathys May 28, 2011
    When asked to select brand of microwave Tappan wasn't listed. I did list the information in a previous section of the form and is as follows: Tappan Turnabout Microwave Oven, FCC ID: ABM964T04,
    The oven is built-in and integral with a conventional oven and of course replacing it because of the inoperative turntable is an expensive option. The unit is about 22 years old.
    Your response is appreciated.
    After further investigation the part number was wrong. The correct part number was nowhere to be found on the microwave unit. It was found on the registration card, which fortunately I was able to locate and is 57-2707-10/03.
    I found a site that lists the motor but states call for price. I'll have to wait until Monday. In the meantime, do you have the procedure for replacing it?
    Guru:
  • 666 Answers
The microwave oven's turntable plate is commonly driven by the mechanisms of a turntable motor. This part of the microwave oven is very important for it helps cook the food evenly. This turntable motor is continually rotating despite the fact that the heat switches from on and off cycle during cooking.
Problems that commonly arise with the microwave turntable like it stops spinning can be the result in the failures of the turntable motor, turntable coupling/drive and the turntable roller ring.
If these components are faulty, replace them immediately. Below are the steps on replacing the microwave turntable.
Here's how to and what to consider in part replacement in case needed so:
Step 1 - Identify
Identify the correct turntable for your microwave oven. All microwave turntables are definitely not the same. They can be identical in the physical look and measurement, but you can't easily match any turntable to any microwave model by the basis of sight only.
Specific turntables are used for specific models. For instance, a turntable made for Panasonic model will not likely fit in a Kenmore model although they may look similar. The turntable on the old models may not fit the latest models of the same brand.
Step 2 - Brand and Model of Your Microwave
To find out the correct turntable that you need, you need to identify first the brand and the model number of your microwave. The model number can be located on the same label containing the serial number as well as the manufacturing date.
This tag can be found commonly inside the oven on either the back or the left hand wall of the unit. Sometimes, it can be located on the side of the panel frame or inside the door frame.
Step 3 - Part Number
As soon as the model number had been obtained, obtain the part number with the manufacturer's website or an online retailer. Most of these sites have turntables that are categorized according to model numbers that have the corresponding part numbers.
When you have already the part number of the needed turntable, shop around before purchasing and you will find a wide range of turntable prices. Those manufacturers and large companies have the highest prices. Be wise in choosing the online retailer on which you will purchase the microwave part.
There are some instances that it will be a wise decision to purchase a new microwave oven than to replace a damaged part. For example, if you have a 10-year old microwave oven and it will cost you a lot to buy an expensive part, it will be economical if you will buy a new microwave oven.
Step 4 - Unplug your microwave oven
If you have already the new turntable part on hand, then you are ready to replace the damaged one. Unplug the oven from the main outlet and carefully remove the damaged turntable and the ring.
Step 5 - Remove the motor housing
It is recommended to place a towel on the flat working surface and cautiously turn the oven upside down. Retaining screws must be removed from the motor housing and then lift it off.
Step 6 - Replace turntable
For consistency, mark the different positions of the wires, unscrew the turntable and replace it with the new turntable with the same appliance part number with the damaged one.
Step 7- Reconnect the wires
Using the marks, reconnect the wires and fit out again the screws and the motor housing.
Step 8 - Test it
Return the oven to its upright position, plug it in and test the operation of the motor if it functions properly.
Unfortunately, I don't know the brand and model of your Microwave Oven. The solution I offered is generally for all Microwave ovens whose turntable stopped rotating even though the oven is ON. Thank you for visiting FixYa! should you have any questions please feel free to post it here.
Posted on May 28, 2011
  • 1 more comment
  • rey francis basa
    rey francis basa May 28, 2011
    22 years old huh. That explains it. Anyhow, I went to this website, http://www.appliancepartspros.com/_tappa... and was able to locate Tappan. Unfortunately I don't know what model you have. The FCC number you provided was recognized as a GE air conditioning unit. You can try looking for the model number and going to the site above and see if it helps.
    Thank you for visiting FixYa! have a good one.
  • rey francis basa
    Nice luck! Unfortunately upon checking for the part we need, it shows that most of the parts for this equipment were tagged as unavailable since manufacturer had stopped manufacturing them.
  • rey francis basa
    I found a manual but this looks like it was made before I was born, it is not that detailed but I hope it helps. Go to this website http://www.appliancepartspros.com/partse.... You will find it there.
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Posted on Jun 26, 2007
  • 6 Answers
SOURCE: Tuntable keeps rotating when microwave door is open
get a new microwave its nackered
Posted on Apr 15, 2009
Sure, if parts are available.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find links to helpful exploded view diagrams and part ordering help here.
Apr 22, 2013 | Microwave Ovens
Panasonic inverter microwave: when i shut off the lid, turntale automatically rotating
When you close the door the turntable comes on? Almost all have a safety switch in the side of the wall where the door closes, An inspection inside the unit will show if switch is damaged or out of position which could cause this problem.
Dec 17, 2012 | Panasonic Microwave Ovens
Light goes out and turntable stops, but still hums like power is still on.
You have a bad door switch that will need to be replaced.
May 13, 2012 | LG Microwave Ovens
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
I have a Whirlpool AMW545 built in microwave oven. The turntable continuosly runs with the door shut when the microwave is not in use. The turntable will stop rotating if the door is opened.
the controller for the turntable is shorted out or welded its contact if its a relay. the door has safety switches that turns off the electrical connection to the turntable and magnetron once you open the door. you can trace the switch that runs the turntable. start from the power supply, goes to the door switch then to the controller before it goes to the turntable motor. i'm sure it has an electrical diagram at the inner wall of the cover.
i hope i was able to help.
Jun 27, 2008 | Whirlpool Microwave Ovens
No heat or turntable motion
This is usually caused by either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383 or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 01, 2008 | Sharp R-403HW Microwave Oven
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
Microwave Ovens Logo
108 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
