Question about Eureka 421A EZ Kleen Bagless Stick Vacuum
Vacuum makes louder than usual loud noise and seems to run at a super high speed. I wonder if a belt needs to be replaced.
4 Suggested Answers
MATRIX_MMX
  • 209 Answers
SOURCE: loud noise
Dear ahut
YIKES, please do NOT do that to your poor vacumn cleaner!!! That is probably the most dangerous question I have heard that relates to a hoover. (but heya friend, this is not your fault, its the fault of the your vacumn cleaners manufacturer/ vendor, as they dont make technology easy to understand. If they did, they would be out of business, as everyone would be servicing there own appliances/ vendor not making any money through the aftersale care plans)
Now the reason why oiling a vacumn cleaner is dangerous....Right, inside your vac, there is a very large, and very powerful AC motor that turns at high speed (which provides the basis for suction through the unit) and this motor will get HOT very quickly. Now the thing wth oil, when it warms up, it starts to displace itself (spread out/ expand over an area) and if continued to be heated, then it will CATCH FIRE.This is especially so, if either you apply the wrong oil or oil to the wrong part of a motor.
Now your vac is making some really weird noise, or it seems to be misbehaving (getting louder when it clearly shouldnt), then there is really only two things that can cause this kind of fault. Your first one is an exhaust block (air that is expelled through the vac, in order for the vac to "breathe" and not overheat. This can also be the same for a blockage anywhere else in the system, so i reckon you should start by giving it a thoroughly good clean, and use a dry cloth to clean out the exhaust areas and any other air flow within the vac. Now with the feeded hose/ pipe (the pipe that supplies the vac with the dust from your floor) can be removed and washed out in warm soapy water, then allowed to dry thoroughly before putting back into the vacumn cleaner. Once this is done, you have sucessfully carried out a 6 monthly maintenance of your vac appliance. (do this every 6 months or when there is a clear dirt buildup, whichever is sooner).
Now the second fault is a little harder to deal with, and this WILL require the consultation of an engineer (electrical/ electronic/ mechanical, as you may be looking at overhauling an AC motor.
Now normally AC motors witll have a set of brushes in them, these in affect form the basis of allowing the motor to turn, and these brushes can wear out over a period of time (not very common in newer appliances) and hence, will need to be replaced if the motor is to function properly and not end up condemned. You will need in effect, to strip down/ disassemble the motor unit to get at the brushes and then inspect them before changing them. Now this can be a very awkward job especially if certain manufactured models of motor are installed in your vac (generally speaking, Bosch are easy enough to strip down and rebuild, and parts are cheap too).
Now if your motor doesnt have brushes, then it more than likely will have a set of ball bearings in it (to make mechanical movement smoother and easier) and these bearings too can wear out. In addition to this, a vacumn cleanner is designed to pull dirt and dust into it, now any motor or motor windings (the copper core inside the motor) and bearings can quickly become damaged if the parts get fouled up or abraised by grit or large particles of dust. Now if you think that the motor unit is spinning up at over a few thousand revolutions per minute, it doesnt take much for a piece of grit to find its way into the motor area and start to ruin internal components, now any part of the motor or moving mechanical parts that start to decompose/ breakup inside the vac unit, will start to make noticable noise and vibration during use. When this occurs, the vac unit should be dismantled carefully and then the motor should be carefully taken apart on a white board (piece of white solid board) as so any foriegn objects or grit will be discovered. This will also reveal whether any internal components have been damaged. Now if there is damage, and in particular, if there is any copper wire, or copper material that has been digested by the motor, then the entire motor unit must be discarded as the windings are breaking up, and the cost of having the motor re-wound is not financially viable, and this evn has to be done by the manufacturer/ vendor of the motor, or by someone who really is quite qualified with these pieces of apparatus.
Now once the vac has been dismantled, and the motor has been dismantled on a white board, it is recommended to clean all of the components one by one, then put them all back into place (re-assemble) and then your vac should be as good as new once again.
Where possible, and of course cost permitting, any filter should be renewed, however a thorough good clean on the non-paper type should be sufficient unless the filter is worn out (which would explain why the vac is failing in the first place).
I hope that this information has been of use to you, and please feel free to contact me here anytime you like regarding this matter, and should you feel confident enough to perform all of these above processes yourself, then i can advise and instruct you on this too.
In the meantime, i bid you take care, and hope that you find this is the fixya for you, and please DO NOT oil that vacummn cleaner, unless it is just bearings or spindle.
Im here as said anytime you need more information or if you have a question/ comment.
yours sincerely
oz
Posted on Apr 14, 2008
SOURCE: LOUD noise
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40870&thid=829059
LOUD noise
Posted by skerfoot85 on July 24, 2008
Turned on vacuum one day and it made a really loud noise like the belt had broken. So we replaced the belt correctly, and turned it on and the noise is still there it is also rattling violently. HELP PLEASE…. not exact same model but close enough
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be a couple of problems, it could be a bad brushroll, it could be a broken fan, the belt braking would not create a loud noise – it would be the brushroll or the broken fan or possibly a broken brushroll housing. Please… have it check out by your local vacuum cleaner dealer in your area or contact the Hoover website or cust serv @ the Hoover factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 25, 2008
SOURCE: I have a eureka capture+
Don't have the solution but have the same problem with mine and it's the same model.
Posted on Nov 28, 2010
Vacuum is loud
Check for clogs starting with the air passageway at the bottom....
a piece of TV cable is great for clearing clogs there....check all
hoses...check for dirty filters. If you find no clogs remove the
brush bar and belt and start the vacuum...if the vacuum is no
longer noisy the problem is the bearings at each end of the brush
bar..... WD 40 may fix or you will have to replace. If after all this
the noise persists the the problem is in the motor. (If you use WD 40
make sure it is dry before you vacuum carpet)
Regards,
Dennis
Aug 15, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Making loud high pitched noise and no suction. Belt seems fine
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
Jul 08, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Loud noise and appears the belt is slipping
Generally you will find soil and string of some sort wrapped around the drive spool. Make sure you unplug it before starting and it might be quite hot.
Dec 12, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Loud noise and smell of rubber over heating
sounds like you have something stuck in the beater bar/roller and the belt is slipping. You're probably going to have to take it out and replace the belt. Also check for wads in the passages.
May 07, 2009 | Bissell 9200 Upright Vacuum
Electrolux aptitude upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=113651&thid=541998
Posted by inoubliable on Apr 24, 2008
My Electrolux is about 3 years old. Never had any problems with it until recently, it is LOUD. It doesn't seem to make a 'normal' running noise unless it butts up against a wall, furniture, etc. trying to vacuum is like being on a jet runway. Is something clogged? Does it just have issues from not being used for about a year? (Last house had no carpet).
It sounds to me that you have a broken fan, in every vacuum I have seen with the loud noise such as you described, it has been a broken fan or fan blade and is in need of replacement. You can try to do it yourself but I suggest going to your local vacuum cleaner dealer for service with the problem. Remember, a suggested belt change if the belt is flat would be 4 to 6 months and If you have a geared belt the belt change would be one year or better depending on wear factor. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Electrolux EL5010A Bagged Upright Vacuum
Eureka 421A EZ Kleen Bagless Stick Vacuum Logo
154 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
