Question about Dryers
My kenmore dryer 417.880427 is making a humming noisy took a look at the belt it seem fine?
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Dryer hums when turned on but won't tumble
If it has a start capacitor, could be faulty. try it without the belt on , and flick the motor by hand , if it goes then motor is probably o/k.
Posted on Nov 18, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Posted on Apr 08, 2009
SOURCE: dryer won't turn. have cleaned & belt seems
the rollers (?) that turn the drum might need some lubrication ---- same thing happened to me and the tech removed the rollers (?? don't know the right word) and lubricated them ---- all working fine now
Posted on Sep 04, 2009
Kenmore dryer will not turn clockwise belt is attached and tight unfortunately I do not know the model of the dryer it doesn't spin just makes a humming noise and won't stay on any suggestions?
sounds like the belt has slipped off the pulley and is stuck and it will not turn,remove the belt from the pulley where it is stuck and you should be fine.
Aug 28, 2015 | Kenmore Dryers
Why dryer won't tumble?
The belt could be worn and stretched.
Jul 20, 2014 | Maytag MDG2706A Gas Dryer
Kenmore Electric Dryer HE2 model 110.8756 really noisy with screeches and rattles when running. Dries fine but really noisy. Used to be quite as a mouse.
there's a belt kit you can buy that comes with a new belt,rollers and the belt pulley.this should take care of it,you have to send the whole model number so i can look up your machine.
Oct 07, 2013 | Kenmore Dryers
The dryer is working but is very noisy, I checked the legs on the bottom already and they seem to be fine.
Check for worn drum bearings or rollers, and check the belt tensioner pulley for worn bearings (don't forget to look at the arm pivot bearing).
Jan 23, 2011 | Kenmore 63032 Electric Dryer
Noise when button pushed to begin dryer.
is it a humming sound and the motor doesn't turn on or is it running and noisy?if it's just humming it's probably a bad motor,try to move the drum by hand,if it turns freely you have a bad motor,if it's running and noisy you could have a bad blower wheel behind the duct that the lint filter slides into or a bad pulley that the belt raps around,bad rollers,there's a few things it could be,you're gonna have to get in there and take a look or call someone in,if it's very old you might not want to put any money into it,next time send model number and a little more info,good luck
Mar 25, 2010 | Kenmore Dryers
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Hum but wont start
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Oct 03, 2009 | Kenmore Dryers
Humming noise on each rotation
Dryers need to be taken apart for cleaning and lubrication when they get noisy. The toughest part is getting the belt off and on. If the machine has a few years on it, a new belt is a good idea while it is apart.
May 05, 2009 | Kenmore Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
