Question about Little Giant Plumbing
The pump was working fine, then approx. a day later it started popping the main breaker. I checked for debris cleaned the pump and then tried plugging it in again. It still keeps blowing the breaker. Can this be repaired? I have model # 9S-CIA-RFS witha 2" opening.
  • 29 Answers
Most likely have a short. replace the pump.
Posted on Jul 15, 2011
Was working fine. Tried a few days later to dry a load and the starter wouldn't turn load on.
First. Check voltage if its a electric type flip breaker all the way off than back on sometimes breaker flips halfway. Then check for a thermal overload near blower housing usually long and white if it fails motor won't run
Jun 12, 2015 | Dryers
Pump wont turn on
make sure heat maintain is off if ok new pump
Apr 04, 2014 | Pentair Pool & Spa
I got the bike rode for a while it sat for a couple of weeks and when I tried to start it it was dead. I tried getting the battery charged and it didn't work. I got a new battery and that worked for about...
If the bike is losing ALL power, I'm talking about dash lights, headlight, tail light, ALL lights, it's probably something tripping the main breaker. The breaker should be located either under the seat or behind the trianglular panel on the right side of the bike. I'd look for a frayed wire near the starter or around the rear cylinder due to the head in that area.
Good Luck
Steve
Nov 12, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
My unit was working fine until 3 days ago when the breaker tripped, I reset the breaker and worked fine for a day then tripped again when it tripped both the ac breaker andthe main in the trailer as well...
High amp draw can be caused by a few different things, so first check that incoming voltage to trailer is sufficient. (115 volts) Not unusual for some parks to install more hydro hook-ups on a feed line, and when all are up and running, your incoming voltage could be decreased. If your o.k. that way, then I'd start looking at the compressor circuit of your ac, in particular, the compressor start-up capacitor. The capacitor basically stores electricity and boosts it to higher voltage for compressor and fan start-ups to reduce current draw that will trip the breaker. Please have a knowledgeable electrician, or RV tech check this for you, as a capacitor can give a real good high voltage (possible fatal) shock, even when power is off to unit. I also suspect that the start relay has shorted (welded) itself due to high amp draw situation, and that is reason it comes on by itself.
Jun 21, 2010 | Dometic Rooftop RV Air Conditioner
Refrigerator trips circuit breaker
try standing it upside down for a day it will work
May 28, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Pump was working fine yesterday popped the breaker
Hi Mohn,
Don't know your geographic location, but where I am we've been in the single digit temperatures for three days. Everything that can freeze has frozen.
If you are in a similar area, even though the water in the spa (I'm assuming the spa pump is being used on a spa) is heated, the pump housing isn't. If it iced up, it could very well cause the problems you describe.
Comment back with some more detail before I continue down what might be the wrong path.
Best regards
Mike
Dec 11, 2009 | Aqua Flo 2 HP Aqua-Flo Pump: 2" in/out,...
2000 Crown Vic cranks but won't start.
Check the fuel pump reset switch again, if it is popped back out then replace that little switch in the trunk, any ford one will do. it works off a magnet and a bearing to close the circuit for the fuel pump. easy fix.
Oct 05, 2009 | 2000 Ford Crown Victoria
Plumbing Logo
256 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
