2000 Dodge Durango Logo
Posted on May 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2000 Dodge Durango 5.2L. It starts fine, but it stalls unless my foot is on the gas. When it reaches idle speed it cuts off. I can even get it into gear if I do it while my foot is on the gas, but as the truck decelerates, it cuts off. What am dealing with here?
Jeffrey Turcotte
Level 3:
  • Dodge Master 8,991 Answers
  • Posted on May 27, 2011
Jeffrey Turcotte
Dodge Master
Level 3:
Answers
8991
Questions
7
Helped
4372960
Points
33683
Sounds like a vacuum leak, but please see my tip at http://www.fixya.com/cars/r7427423-fix_poor_idle_high_idle_stalling_fuel . These are generic instructions. If you getstuck or need specific instructions for your car, please get back to me with model, year and engine info.
My Durango starts if I give it gas and stalls when I let off the gas won't idle, help what to look for?
My car dies when I let off the gas - CarGurus
www.cargurus.com > Questions > Dodge > Durango
CarGurusDec 5, 2012 - My car dies when I let off the gas - I have a 2000 Dodge Durango SLT, I bought a month ago. I noticed it had a slow start but it still started and ran fin... ... Also, the oil pressure was high until it could idle by itself then it was back to normal. ... sometimes if you give it more gas it stays running but now it won't ...
dodge dakota idling and dying - CarGurus
www.cargurus.com > Questions > Dodge > Dakota
CarGurusApr 12, 2011 - dodge dakota idling and dying - My dakota will start then idle down and die. I can pump the gas and it will stay running but if i hold the peddle down or . ... thatdies on me at stop signs and when I take my foot off the gas pedal. .... and truck pops..misses and runs like crap and wont stay on unless i give it gas, ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
www.dodgedakota.net/boards/v8/4240.html
Aug 9, 2003 - 21 posts - ‎20 authors
3helpful
2000 Durango has no codes and die win hot what would. Make this happen is runs grant til a warm day and if u site. For a bit it will or if you deccellerate and it will start. Right. Back up I can find the...
2000 Durango,No code thats okay we have the symptom that all we need. Stall when hot.So it stall at idle or if you decelerate then it also stalls.and it start right up. The 2000 Durango is equipt with a ISC (idle speed control motor) and this is mounted on the throttle body.This maintains a target idle speed.The ISC also uses a desired MAP for deceleration.Your solution is a throttle body cleaning,or a ISC (idle speed control) motor.This is the only thing that can cause what is described
Durango stalls
This could be allot of things like clogged intake manifold or a bad fuel pressure regulator or EGR valve to even a dirty intake air filter or plugged catalytic converter that's just to name a few
2answers
2002 durango has recently started to stall after it has been filled up. today it would not stay running unless foot was on the gas at all times
try this.
Here is the common cause of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
13helpful
2answers
99 Dodge Durango Dies When Slowing
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
1helpful
2000 durango 5.2 cold starts, engine stalls or rpm surging
i know this may sound stupid but if your battery is old or a little weak on this vehicle the idle air control solenoid will act speradicley hunting for were it should be and the vehicle will stall.replace battery
2000 Contour dies at low idle
you could try to clean the mass air flow sensor
2answers
Car trouble
Try cleaning or replacing idle speed motor.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
