Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
I have a kohler commandpro 14 hp on a bobcat mover. motor stalled after flooding while running. have removed and cleaned carb thoroughly,replaced gaskets and breather hose. two pulls and fuel pours out of muffler. what could the problem be?
Float is stuck, or has a pin hole in it, if your carb don't have a float the needle is stuck in the open position
Posted on May 27, 2011
Have a murrry mower with 12 hp moter put a cut off on gas line some times runs ok then will start flooding if you cut gas line off start engin it will run a second or two then start blowing oil out an
If you have a float style carb I believe the float has become a "sinker". Pull the float bowl off the carb and set aside. pull the float pin and also set aside. carefully remove float and needle, set needle aside. Shake the float near your ear. If you hear sloshing in the float, replace it. No? check needle and seat for wear, or since you're into the carb this far replace them. This info is based on Tecumseh carbs, but B&S or Kohler should be similar. If there are any other questions don't be afraid to ask. There is no such thing as a stupid question.
Jan 29, 2013 | Briggs & Stratton Garden
Walbro Carb flooding 13 hp Kohler
the needle valve in the carb is not seating change the needle valve and seat also check the oil when this happens gas drains into the crankcase if so you will need to change that as well
Jun 28, 2012 | Garden
27 HP Kohler stalls on bumps
sounds like a loose connection
May 13, 2012 | Garden
Kohler 17.5 HP floods after turned off over night. Gas spits out of muffler when you try to start. It`s hard to start but run fine after engine starts
Probably a leaking float valve. If it has a fuel shut off, use it, and run it out of gas after each use.
If you pull the bowl off the carb, it's the valve attached to the float. cleaning it may help, or replace it.
Jul 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Raw fuel coming from muffler when i crank it it is a 16.5 hp kohler eng
Typically this is caused by a sticking float in the carburator. It's essentally flooding itself out. You can take apart float bowl and clean the carb. For the float specifically, remove the pin that hold the float on and then remove the needle valve below that. If you want to go all out and do it right, get yourself a carb rebuild kit. They are very inexpensive and easy to do yourself
May 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
295 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
