Question about Bertazzoni X366PIRX Dual Fuel (Electric and Gas) Range
The handle on the oven door has come loose and I cannot see how to take off the door to tighten it.
    Master:
  • 448 Answers
Look around the inside or the out side edges you will find Phillips screws you need to
remove them now the inner and outer skins will separate and you can tighten the handle
from the in side once you tighten the handle up you can put the door back together
i hope this helps you
bob
Posted on May 28, 2011
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
I have a loose door handle, how do i fix it? Do i have to take the door off?
Hi You will have to open the oven door and take the screws out of the side that faces inwards to the oven. Once the screws are removed the door will come apart. And then you can tighten the screws to secure the handle better. Also before you do that look under the handle and make sure there are not any set screws in it that tightens down to an anchor. They usually will be hex or allen screws .
Dec 16, 2010 | Magic Chef CER3760 Electric Kitchen Range
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
I have a kitchenaid electric range and the oven door handle is loose. Can I remove the door and open it and tighten the handle?
My son came and pulled the door straight out not up and we were able to take it off and take it apart and tighten the handle and clean the inner glass. It now looks and works like new.
Thank you
Karen
Aug 07, 2009 | KitchenAid Kitchen Ranges
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Bertazzoni X366PIRX Dual Fuel (Electric and Gas) Range Logo
120 people viewed this question
Top Bertazzoni Kitchen Ranges Experts
Dan Webster
Dan Webster
 Gary Gemmell
Gary Gemmell
Anthony Kelly
Anthony Kelly
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
