Question about Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
Voltage shows 80 on 110v and 155 on 240v - Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
If you take the end of the generator off you will see a rectifier or four diodes with a varister or a full wave brige rectifier, sounds like you have a bad diode, or a shorted exite winding to the rotor, the exite winding is a small turn winding feeds the rectifier board that ac signal is converted to dc to feed the rotor ,the rotor produces a magnetic field which rotates inside the stator windings , the magnetic lines of flux from this field cut through thre stator winding inducing a voltage in the stator coils. hope this helps
Posted on May 28, 2011
Voltage
Motor will run with 80% rated voltage that shows on nameplate.
Typical household water heater nameplate will show on side of disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe voltage that shows on side of device.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 06, 2013 | In-Sink-Erator InSinkErator Evolution...
Motor not working but display is shows motor bad
1) adjust the speed sensor see the diagram, clean it and tight the wiring connectors very wells.
2) measure the input voltage motor , if there are voltage the motor need repair.
3) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block
4) after fix it, RUN the software calibration for diagnose, and troubleshooting.
God bless you
7_14_2012_9_15_53_am.gif7_14_2012_9_16_15_am.jpg7_14_2012_9_16_36_am.gif7_14_2012_9_16_49_am.gif
Jul 13, 2012 | Exercise & Fitness
How many watts does a 59516-751 model require to run?
Answer
Simple Answer is just to know two formulas
Ohm's Law
V = IR
Power
P = IV
From those you can calculate voltage, amps, watts, ohms
V = Voltage (volts)
I = Current (amps or amperes)
R = Resistance (ohm's)
P = Power (watts)
Just solve for what you are missing.
Voltage times amps being drawn shows watts produced.
Watts divided by voltage shows amps being drawn or watts
divided by amperage shows voltage applied.
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
I have a codes 13, 26 and 39 flashings and need to know their meaning
13 -O2 sensor voltage between 0.35--0.55 volts with throttle angle above 4%
26-Quad driver sense shows low voltage when should show battery voltage or reversed bat when should be low voltage
39-TCC was commanded by ECM when trannie was in high gear but engine speed didn't indicate TCC engagement
Sep 26, 2010 | 1992 Oldsmobile Cutlass Ciera
Haier air conditioner show E7 error and does not work
same problem because of voltage problem . here voltage was 400 so it was show e 7 then i made my voltage normal and ac is working good (y)
Jul 07, 2010 | Heating & Cooling
I have a yamaha ef3000iseb generator. Runs well, but puts out too much voltage, about 150 volts. Bought service manual, only shows weak or no voltage , nothing on high voltage.
The model you have shows to be a Inverter. You may have a defective voltage regulator. Visit the below URL for a dealer near you.
www.yamaha-motor.com/outdoor/dealers/dealerhome/home.aspx
May 31, 2010 | Electronics - Others
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator Logo
342 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
