Question about HP Photosmart M537 Digital Camera
Lens wont move in or out
The lens on my camera wont move in or out and i put new batteries in it
  • Anonymous Oct 26, 2008
    my lens will come out all the way but the shutter will only open partially
    when the lens goes in when you shut the camera off it goes in all the way except the last 1/4 and the shutter stays open
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 16, 2012
VOTIT
  • 2071 Answers
SOURCE: beeps three times lens is stuck out and won't come on
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these E18 repair instructions useful, consider bookmarking this page or posting your experience in the posting area. If you have any ideas for improving the web site, so it can benefit more people, feel free to share them with us
Posted on Jul 16, 2008
  • 11967 Answers
SOURCE: lens wont retract into camera
Sounds like the lens barrel has been damaged. Does it look as if it's pointing slightly sideways or is it not perfectly round anymore?
Posted on Aug 12, 2009
SOURCE: camera wont turn on and lens wont go in and i just
Lens of the Camera doesn't retract:
Before trying any of the suggestions, make sure that the Battery is
fully charged and in recording mode.
fine.s
3) Try forcing the camera lens:
(a) Turn the camera off.
(b) Take the camera in one hand and with the other gently take one part
place.
(c) Power the camera on.
improving.
Posted on Dec 02, 2009
  • 3 Answers
SOURCE: lens wont go in
I had the same problem, my workaround was:
1. turn on the camera, you will hear some beeping as the lens tries to raise from the body of the camera
2. wait until the camera turns off
3. pull the lens gently until you hear a 'click'
4. turn on the camera again, it will work normally (hopefully)
Another interesting thing, you can switch on the camera in "play mode" only, by holding down the play button on the back while pressing the power button. In that way, the lens will not raise and you can copy the images.
Posted on Jul 14, 2010
SOURCE: battery drained and now lens wont retract and ive put brand new fully charged rechargeable batteteries i9n and still wont power opn or anything
I have the same problem.I forgot to get the battery from the camera s when we get the battery inside the camera then charged the battery when we put the battery to the camera it didn't work and no power, I've tried fixing the camera what's the problem and I think it was drained.I've also tried to go to the Canon company technician and they told me that there's nothing that they can do cause it was damaged already and they told me to just new one but my camera is just new s please help me what to do or any solution...thanks and here is my email baby_sykrich@yaho.com.
Posted on Feb 22, 2011
How would I know if my camera is full?
Try brand new batteries - sounds like weak batteries since the lens won't move.
Sep 02, 2016 | Kodak EasyShare M1033 Digital Camera
Telephoto lens stuck
batteries might need charging or try new batteries.
Jul 04, 2014 | Panasonic Pal Version Lumix Dmc-fz47/fz48...
Batteries Dead and lens wont retract.. I just got
There are some cameras who give problem when they are new. Give it some time i am sure it when the battery is on the move it automatically repaired.
Aug 19, 2013 | Olympus SP-820UZ iHS Digital Camera, 14MP,...
Wont turn on and lens wont extend. Put in new fully charged battery but still nothing. Can hear motor but nothing works.
This is may be a camera battery problem or a lens error. Try Li-ion batteries first and see if anything better
May 19, 2011 | Kodak EasyShare P850 Digital Camera
Camera wont turn on and lens wont go in and i just put new batteries in
fine.s
place.
improving.
Dec 02, 2009 | Kodak EasyShare C913 Digital Camera
Lens wont retract with or without new batteries. green light blinks but no lens movemant even using wide/tele buttons
Since you already used new batteries and still lens will not moved and you can just see flashing green it means that the Gar of the camera is defective You may call repair center specialize with kodak camera's at 1 800 665 6515
Nov 09, 2009 | Kodak EasyShare C340 Digital Camera
Lens wont move and camera wont power up
It's time for a new one, uneconomical to repair.
Jan 11, 2018 | Kodak EasyShare One Digital Camera
Total power falure
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
HP Photosmart M537 Digital Camera Logo
22 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
