Question about GE Refrigerators
We moved our sons 5 year old GE pss 26lg to our house yesterday. Plugged in and attached water. Runs fine for refrig and freezer but isn't making ice and water flow is weak. We've put rocker switch behind the ice reservoir in both positions and no change. Any suggestions ? Thanks, Charles S.
    Sergeant:
    Champion:
  • 257 Answers
Rocker should be down but check to see if there are any kinks in the hose or if the water pressure is good before you hook the hose to the refrigerator inlet. there may be a block somewhere, including the shoot that the water comes out in the refrigerator, That may freeze up with ice if there is a slow valve leak.
Posted on May 27, 2011
Ge profile .. refrig water leaking from freezer door near lower hinge.. seems like the water line?? any help ??
Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
PSS service manual
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge refrig is 30 yrs old...operating normal until yesterday. It constantly runs. the freezerer does not freeze, the circulation fan is not running in the freezer and the lower is cool but not cold.
Good day,
The freezer fan motor going bad, would cause all the symtoms you described. Remove it, take it to an appliance parts house, where they will be glad to test it. If bad, replace.
P.S. Always replace the blade as well when replacing a GE motor.
Mar 18, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
We have a refig.. with top freezer. Freezer works fine, refrig. is not working, motor still runs when turned up. About 8 years old. What could be wrong?
Make sure the fan in the freezer is running. if it is . More than likely the vent has ice in it. take the bottom out of the freezer and you can get to it. throw the ice and then check the drain. is right behind the vent.
Sep 23, 2009 | GE Refrigerators
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Refrigerator is too cold
You have bad Thermistors they sense the temp in the frezzer and the ref section they are about $15 each and the same part #
May 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
