Question about Sylvania HT-6051F Theater System with Wireless Speakers
Have Sylvania wireless system and trying to hook up transmitter so speakers will work. No instructions
4 Suggested Answers
  • 133 Answers
SOURCE: panasonic BT100 & sh-fx67 kit surround sound not working
make sure you have speakers A and B on, sometimes that is the problem
Posted on Jan 11, 2009
joboo1
  • 257 Answers
SOURCE: can't connect wireless stereo to sylvania 6620LF4
Hi, Ok, I now understand what the problem is. Sorry I missed the fact that it is due to no audio outputs on the TV. The audio board is designed to power low impedance speakers and doesn't have a big power amp to drive them. I do not have a schematic of that particular TV so I do not know how the headphone jack is wired. The way it basically works is, when you insert the plug, the tip pushes a contact away from another contact thus making one circuit and breaking another. You can test this externally by inserting an unwired plug or look at it from the inside and bridge the tip connection. I would only advise this if you have some technical skills. Other than that the thing is working like it was designed, they don't want you to use both. Sorry, I hate to give this type of news, but I am one of the only ones who will. Good Luck to you!
Posted on Feb 20, 2009
Techjoel
  • 79 Answers
SOURCE: Sylvania wireless mouse not working
Press the button on the reciever, then press the small recessed button on the bottom of the mouse (may need to use point of a pen).
Good luck,
Techjoel
Posted on May 25, 2009
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
Can I hook up other speakers instead of the orginal ones
yes you certainly can. If the speakers fit the jack, then you can use any speakers. You can even use a wireless transmitter and even hook it up to a stereo system.
Aug 12, 2010 | Logitech Z-5300 Computer Speakers
Philips LX3950W - no signal to rear speakers
check to se if your reciever channel number is set to the same as your transmitter channel number. press and hold down sound butten on remote to set transmitter number .set reciever number button on reciever unit. try setting both to number 4.
Dec 29, 2009 | Philips LX3950W System
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
Can't get the bose cinemate to work all hooked up fine get static coming through them upon connection but then nothing????
Never buy a wireless speaker system! Too susceptible to interference, and the RF transmitter/receivers will drift off frequency in a short time, leaving you with perfectly good but useless speakers. If it's a used system, there's not much you can do. If new, of course you can take it back and get a REFUND - don't exchange them for another wireless system. Run wires, live with the mess and enjoy proper performance for years.
Dec 13, 2008 | Bose Cinemate Digital Home Theater System...
Sa-pt750
Is your main set is on while the transmitter card in inserted on main set?
If so, try do "pairing process" to pair up main set and wireless unit.
Pairing process can found in Operating Instruction manual which come along with the main set.
Jul 19, 2008 | Panasonic Home Theater System System
Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Jun 08, 2008 | Panasonic Home Theater System System
Sylvania HT-6051F Theater System with Wireless Speakers Logo
52 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
